Page 1 of 2
Panel Cointegration Test
Posted: Fri Nov 22, 2013 9:18 am
by allister
Hi Tom
I have a question about the use of panelfm and pancoint.src, written by Pedroni.
I have a rather simple question that I need some insight regarding testing for cointegration in a panel setting using the Pedroni Test. I have read alot of papers and still have a hard time deciding when to reject the null hypothesis on no conitegration.
After the estimation (with panelfm) you can obtain the results of Pedroni tests with pancoint.
However, I was wondering about which are the appropriate critical values to be taken into account, in 2 different respects, I have five regressors including the dependent variable and a intercept.
1. small sample. I have a panel with N=13, T=26. How do I take into account this fact?
2. number of regressors. I have a model with five regressors. Do I have to use Table II in Pedroni 1999 (Critical values for cointegration tests in heterogeneus panels with multiple regressors)?
Thanks a lot for the help that you could give me!!!!
In addition is there anyway to code the test Kao and Westerlund test in Rats?
Re: Panel Cointegration Test
Posted: Mon Nov 25, 2013 12:54 pm
Pedroni(1999)'s table 2 doesn't give critical values---it gives means and variances of the test statistics under the null. You don't need to use that because those are incorporated into the standardized test statistics reported by @PANCOINT. As with many panel data statistics, those have double-asymptotic distributions (large T followed by large N) and are asymptotically N(0,1) under those circumstances. Your N is probably less a problem for sample size than your T. You might want to check with Prof. Pedroni as to whether the asymptotic distribution is reasonable with your size data set.
Posted: Sat Apr 30, 2016 11:29 am
by sanjeev
Please tell me how do we decide whether we have to reject or not each of the seven statistics under Pedroni's panel cointegration test? So specifically I am asking for the critical values or p-values in the output.
Please reply soon!
Regards.
Posted: Sun May 01, 2016 7:06 am
From the output:
All reported values are distributed N(0,1)
under null of unit root or no cointegration
Posted: Thu May 05, 2016 9:43 am
by sanjeev
Thanks for your reply! But what about the sign of the statistic?
Regards.
Posted: Thu May 05, 2016 10:13 am
sanjeev wrote:Dear Tom,
Regards.
You would reject non-cointegration in the left tail, that is, big negative numbers would cause you to reject non-cointegration in favor of cointegration.
Posted: Sun May 08, 2016 6:28 am
by sanjeev
Please tell me do we have the options to choose lag length for the ADF regressions according to different criteria like AIC,SBC,HQIC Also what is RATS taking as default criterion?
Regards.
Posted: Sun May 08, 2016 7:04 am
Yes. And that's described in the documentation:
https://estima.com/ratshelp/index.html? ... edure.html. The default is fixed lags.
Posted: Sat Apr 15, 2017 11:42 am
by sanjeev
Is it possible to conduct panel cointegration tests with structural break?
Regards.
Posted: Sun Apr 16, 2017 10:06 am
There is a literature on that (Westerlund and Carrion-i-Silvestre are two people who have done work on that). So far as I know, none of that has been written in RATS.
Posted: Sat Apr 29, 2017 6:05 am
by sanjeev
Can we retrieve p-values also along with the Pedroni's statistics?
Posted: Sat Apr 29, 2017 8:05 am
No. Those are N(0,1). Do you really need p-values for something as standard as that?
Posted: Thu May 25, 2017 12:53 am
by sanjeev
Is there any way to select the deterministic term while testing for the existence of a cointegrating vector and then estimating the model using group-mean FMOLS?
Posted: Thu May 25, 2017 8:44 am
You mean other than the documented DET options in both?
Posted: Thu May 25, 2017 12:12 pm
by sanjeev
TomDoan wrote:You mean other than the documented DET options in both?
No, I mean on what basis do we decide which DET should we include in our estimations,constant,trend or nothing?
Please reply.
