How to code up BVAR Impulse Response???
Posted: Thu Nov 28, 2013 5:33 am
My question is a bit basic, as I dont know how to code up the IMPULSE from the BVAR code in the Bayesian Econometrics Workbook. The code below does forecasting.
Im a newbie in Bayesian VAR, so thanks for your patience and help!
FROM THE BAYESIAN COURSE WORKBOOK:
compute lags=4 ;*Number of lags
compute nstep=16 ;*Number of response steps
compute nburn=500 ;*Number of burn-in draws
compute ndraws=2500 ;*Number of keeper draws
open data haversample.rat
cal(q) 1959
data(format=rats) 1959:1 2006:4 ftb3 gdph ih cbhm
set loggdp = log(gdph)
set loginv = log(ih)
set logc = log(cbhm)
* These are the controlling parameters for the symmetric "Minnesota"
* prior - the own lag tightness and the relative tightness on the other
* lags.
compute tight=.1
compute other=.5
* First, estimate the system with a prior via mixed estimation, to see if
* we come up with something similar via Gibbs sampling.
system(model=varmodel)
variables loggdp loginv logc ftb3
lags 1 to lags
specify(type=symmetric,tight=tight) other
* Estimate with a prior
estimate
compute nvar=%nvar
@BVARBuildPriorMN(model=varmodel,tight=.1,other=.5) hbpriors hpriors
@BVARFinishPrior hbpriors hpriors bprior hprior
compute sigmad=%sigma
dec vect[series] forecast(nvar)
dec vect[series] forestderr(nvar)
* Range to forecast
compute fstart=%regend()+1
compute fend =fstart+nstep-1
do i=1,nvar
set forecast(i) fstart fend = 0.0
set forestderr(i) fstart fend = 0.0
infobox(action=define,progress,lower=-nburn,upper=ndraws) "Gibbs Sampler"
do draw=-nburn,ndraws
infobox(current=draw)
* Draw b given sigma
compute bdraw =%ranmvkroncmom(%cmom,inv(sigmad),hprior,bprior)
compute rssmat=%sigmacmom(%cmom,bdraw)
* Draw sigma given b
compute sigmad=%ranwisharti(%decomp(inv(rssmat)),%nobs)
if draw<=0
next
compute %modelsetcoeffs(varmodel,bdraw)
simulate(model=varmodel,cv=sigmad,results=simresults,steps=nstep)
do i=1,nvar
set forecast(i) fstart fend = forecast(i)+simresults(i)
set forestderr(i) fstart fend = forestderr(i)+simresults(i)**2
end do draw
infobox(action=remove)
do i=1,nvar
set forecast(i) fstart fend = forecast(i)/ndraws
set forestderr(i) fstart fend = sqrt(forestderr(i)/ndraws-forecast(i)**2)
do i=1,nvar
set lower fstart fend = forecast(i)-2.0*forestderr(i)
set upper fstart fend = forecast(i)+2.0*forestderr(i)
graph(header="Forecasts of "+%l(%modeldepvars(varmodel)(i))) 4
# forecast(i) fstart fend
# lower fstart fend 2
# upper fstart fend 2
# %modeldepvars(varmodel)(i) fstart-12 fstart-1
