Errors bands for VARIRF, MC
Posted: Fri Jan 17, 2014 4:55 am
by Ben
Dear All,
I try to apply the Bjørnland, Hilde C. Leitemo and Kai (2009) method for 5 variables (price, production, monetary policy, budgetary policy, and exchange rates).
I applied the code of Bjørnland, Hilde C. Leitemo and Kai (2009) with on short and long restrictions.
I generated the IRFs with VARIRF, then I applied the Monte Carlo method (@ MCProcessIRF) to introduce erros bands to IRFs.
I attach here the program that I wrote.
If you can help me, I want to know:
If IRFs with VARIRF are those of the SVAR?
the procedure for errors bands is right or not?
I want to generate all IRFs for all variables and all the shocks not just two as Bjørnland, Hilde C. Leitemo and Kai (2009) method.
Regards
Ben
Re: Errors bands for VARIRF, MC
Posted: Fri Jan 17, 2014 7:57 am
That looks fine. However, they include
* The rescaling done in the next two lines is specific to this paper
compute fd=%xdiag(factor)
ewise factor(i,j)=factor(i,j)/fd(j)
which normalizes the shocks to units on the diagonal. Particularly with SR-LR shocks, there isn't necessarily a close correspondence between shocks and specific variables the way there is with a simple Cholesky model or even a parametric SVAR. Most applications of MCMC to an SVAR would omit those two lines.
Interpret IRFs and confidence intervals
Posted: Sun Mar 16, 2014 9:14 am
by Ben
Think you Tom for your reply and advices.
Finally i applied the method of Bjornland, Hidle, Leitemo and Kai (2009) as you advised me.
I have some other questions, espesly about the IRFs.
1-How to judge the significance of the IRFs through confidence intervals and positioning of zero axe.
2- In the method of Bjorland: shocks are standard deviation or what exactely (i can not found the information by looking at the%% responses) ?
Cordially.
Re: Interpret IRFs and confidence intervals
Posted: Sun Mar 16, 2014 1:13 pm
Ben wrote:Think you Tom for your reply and advices.
If the upper bound is above and the lower is below, then you would conclude that that response step isn't significant.
Ben wrote: 2- In the method of Bjorland: shocks are standard deviation or what exactely (i can not found the information by looking at the%% responses) ?
As was described in the previous reply, they normalize the shocks to unit size.
Errors bands and IRFs
Posted: Sun Mar 16, 2014 3:10 pm
by Ben
Think you Tom for your reactivity, i still need more precision.
1- I omitted the two lines mentioned above. That is why I wonder if this is one standard deviation.
2- You compare bunds to zero or to the reponses line ?
Regards.
Re: Errors bands and IRFs
Posted: Sun Mar 16, 2014 10:04 pm
Ben wrote:Hello,
Then they would be one standard deviation.
Ben wrote: 2- You compare bunds to zero or to the reponses line ?
If the bounds are on opposite sides of zero, then the response is insignificant.
Shock sign
Posted: Mon Mar 17, 2014 4:27 am
by Ben
The shock are always positive, or can they be negatif ?
If this is the case, how to determine it ?
Cordially.
Re: Shock sign
Posted: Mon Mar 17, 2014 6:20 am
Ben wrote:The shock are always positive, or can they be negatif ?
Cordially.
If you're doing an SVAR, it depends upon the normalization that you've used. If it's a Cholesky factor, it will be positive by construction on the "own" variable.
Sign of shock
Posted: Mon Mar 17, 2014 5:49 pm
by Ben
I apply a SVAR program of Bjornland, Hidle, Leitemo and Kai (2009).
1- this is a part of the program. Can you tell me if normalization used here is a positive or negative shock ?
dec rect lr(5,5)
dec rect sr(5,5)
input sr
 . 0 . . .
 . . . . 0
 . . . . 0
 0 0 . . .
input lr
 . 0 . . .
 . . . . 0
 . . . 0 .
 0 0 . . .
dec vect[strings] shocklabels varlabels
compute shocklabels=||"A","B","C","D","E"||
compute varlabels=||"A1","B2","C3","D4","E5"||
@ShortAndLong(sr=sr,lr=lr,masum=inv(%varlagsums)) %sigma f
* Point estimates
@varirf(model=ben,steps=nsteps,factor=f,page=byshock,$
  shocks=shocklabels,varlabels=varlabels,accumulate=||1,2,3,4,5||)
* Monte Carlo integration
procedure SRLRDoDraws
option model     model
option integer   draws   10000
option integer   steps   40
option vect[int] accum   ||1||
option rect      lr
option rect      sr
local integer nvar
local rect    fxx fwish fsigmad factor
local integer wishdof
local rect    betaols betau betadraw
local vect    ix
local symm    sigmad
local integer i j draw
if .not.%defined(model) {
   disp "###SRLRDoDraws(MODEL=ben,other options)"
   return
compute nvar=%modelsize(model)
* Standard setup for drawing from an OLS VAR
compute fxx    =%decomp(%xx)
compute fwish  =%decomp(inv(%nobs*%sigma))
compute wishdof=%nobs-%nreg
compute betaols=%modelgetcoeffs(model)
local rect[series] impulses(nvar,nvar)
* These are global variables
declare vect[rect]   %%responses(draws)
infobox(action=define,progress,lower=1,upper=draws) "Monte Carlo Integration"
do draw=1,draws
   if %clock(draw,2)==1 {
      compute sigmad  =%ranwisharti(fwish,wishdof)
      compute fsigmad =%decomp(sigmad)
      compute betau   =%ranmvkron(fsigmad,fxx)
   else
   compute %modelsetcoeffs(model,betadraw)
   * Compute the short-and-long-run factor using the recalculated lag
   * sums of the model.
   @ShortAndLong(lr=lr,sr=sr,masum=inv(%modellagsums(model))) sigmad factor
*******   compute fd=%xdiag(factor)
*******   ewise factor(i,j)=factor(i,j)/fd(j)
   impulse(noprint,model=ben,factor=factor,results=impulses,steps=steps)
   * Accumulate the responses as requested
   do i=1,%rows(accum)
      do j=1,nvar
         acc impulses(accum(i),j) 1 steps
   * Store the impulse responses
   dim %%responses(draw)(nvar*nvar,steps)
   infobox(current=draw)
end do draw
infobox(action=remove)
* Restore the original coefficients
compute %modelsetcoeffs(model,betaols)
end SRLRDoDraws
@SRLRDoDraws(accum=||1,2,3,4,5||,steps=nsteps,model=ben,lr=lr,sr=sr)
@MCProcessIRF(model=ben,percentiles=||.16,.84||,center=median,lower=lower,upper=upper,irf=irf)
2- It's possible to explain briefly how to impose positive and négative shock on the program ?
Regards
Posted: Tue Mar 18, 2014 4:00 pm
With short- and long-run restrictions, the signs of the non-zero impacts are generally not set directly as part of the calculation. You have to figure out what it means for something to be a "positive" shock and flip column signs in the factor as needed to make that happen.
