Testing for MS Models
Posted: Thu May 01, 2014 9:11 am
In an MS-VAR (eev_mcmc.rpf), i would like to test for the number of regimes. I was wondering whether I should use the option RESTRICT or instead calculate the LR test statistic (using the command %MSSysRegProb to compute the likelihood values?), after having estimated an MS-VAR with different regimes. In any case, the test statistic would be distributed with a mixture of distributions, which is why it may not converge to a standard (asymptotic) CHI-SQUARE distribution. Then, one solution is perhaps simulate the critical values Monte Carlo simulation. I would appreciate if you could provide me with some programming tips on this issue.
Many thanks indeed.
Kind regards
Many thanks indeed.
Kind regards
