FORECAST EVALUATION: RMSE, MAE, MAPE TIC
Posted: Tue May 20, 2014 9:50 am
by ddngoh
Whats are the codes for MAE etc to enable me evaluate the fitting performance of models?
Re: FORECAST EVALUATION: RMSE, MAE, MAPE TIC
Posted: Tue May 20, 2014 11:03 am
See sections 5.4 and 5.5 of the v8 User's Guide.
Posted: Tue May 20, 2014 2:01 pm
by ddngoh
Thank you very much! :)
Posted: Wed May 21, 2014 6:13 pm
by ddngoh
Hi Tom, Thanks for all your help! I tried computing the MAE but could not! In the file attached, the authors used RATS for the entire work. On page 41, the computed MAE for correlation and volatility forecast as a way comparing. That is exactly what I want to do!
2. In that same work, they plot estimated and forecast volatility as well as realized volatility on the same graph for each variable for BEKK and DCC! They also plot estimated and forecast correlation as well as realized correlation.
Thankx
Posted: Wed May 21, 2014 10:33 pm
ddngoh wrote:Hi Tom, Thanks for all your help! I tried computing the MAE but could not! In the file attached, the authors used RATS for the entire work. On page 41, the computed MAE for correlation and volatility forecast as a way comparing. That is exactly what I want to do!
Thankx
Then you have to compute the realized volatility and correlation in order to do the comparison.
Posted: Thu May 22, 2014 6:35 am
by ddngoh
THANX TOM,
Any help with an example as you do? :D
