Page 1 of 7
Identifying VARs with sign restrictions
Posted: Fri Nov 28, 2008 9:03 pm
by econdawg
Note: most of this thread is now obsolete because the Mountford-Uhlig replication shows how to handle multiple shocks.
RATS provides a code for replicating Uhlig(2005)'s paper which essentially identify VARs using sign restrictions.The code though allows for the identification of one shock. I was thinking about identifying more than one shock at the same time (say 2 shocks). i am kinda puzzled as to how to incorporate that in the code. Would identifying a second shock implies doing a second inner-loop subdraw for another vector over the unit sphere? That is i would still draw initially from the posterior of the VAR then compute impulse responses, but instead of doing one subdraw (and compute vector a) for each draw from the posterior, i would do two subdraws (and compute a and another vector--say b). Then i would be essentially be constructing 2 impulse vectors simultaneously and go from there to check sign restrictions to identify the two shocks of interests. Am i thinking right about this? it would be very helpful (if any of you have time) to maybe guide me as to how i would modify the code in order to identify that second shock. Thanks a lot.
Re: Identifying VARs with sign restrictions
Posted: Fri Jan 02, 2009 3:13 pm
econdawg wrote:Hello,
This shows an example of the subdraw procedure for doing multiple mutually orthogonal sign-restricted impulse vectors. This relatively simple logic will only work if no impulse vector can meet more than one set of restrictions. (Here ik(2) needs to be positive for the first set and negative for the second). If the restrictions don't separate the space like that (they probably should if the whole idea is to make sense), you would have to check to see if either of the restrictions are satisfied by your first draw, then see if the remaining restriction is met by the second.
do subdraws=1,n2
* First Set of Restrictions - Unique Impulse Vector
compute v1=%ran(1.0),v1=v1/sqrt(%normsqr(v1))
compute v=i1=p*v1
do k=1,KMAX+1
compute ik=%xt(impulses,k)*v
if ik(4)<0.or.ik(6)<0.or.ik(2)>0.or.ik(5)>0
branch 105
end do k
* Meets the first restriction
* Draw from the orthogonal complement of i1 (last five columns of the
* factor "f").
compute v2=%ran(1.0),v2=v2/sqrt(%normsqr(v2))
compute v=i2=%xsubmat(f,1,6,2,6)*v2
* Second Set of Restrictions - Demand Shock
do k=1,KMAX+1
if ik(1)<0.or.ik(2)<0
branch 105
end do k
* Meets both restrictions
compute accept=accept+1
dim goodrespa(accept)(nstep,nvar)
dim goodresp(accept)(nstep,nvar)
ewise goodresp(accept)(i,j)=(ik=%xt(impulses,i)*i1),ik(j)
ewise goodrespa(accept)(i,j)=(ik=%xt(impulses,i)*i2),ik(j)
if accept>=1000
break
:105
end do subdraws
Posted: Sun Jan 04, 2009 9:57 am
by econdawg
Thank you very much Tom for your help. And I totally see your point.
P.S what is exactly p here (as in "v=i1=p*v1") ?
Posted: Tue Jan 13, 2009 9:31 am
p is (any) factor of the inverse Wishart draw for the covariance matrix.
Posted: Wed Mar 11, 2009 12:26 pm
by lhlee0506
Hi~Tom,
I am confused about these two lines " @forcedfactor(force=column) sigmad i1 f"& "compute v=i2=%xsubmat(f,1,6,2,6)*v2".
If you could tell me their meaning and why we need them, I will be very appreciated.
Thank you very much!
Posted: Wed Mar 11, 2009 1:30 pm
SIGMAD is the draw for the covariance matrix. I1 is the first identified shock. This computes a matrix F (there are many of them), for which FF'=SIGMAD and the first column of F is a scale multiple of I1. u=Fv is an orthogonalized representation of the residuals and I1 is proportional to F x ||1,0,0,...0||', that is, I1 is the first component in v. We want to identify a orthogonal component in the factorization. The space of those is the span of columns 2 to 6 of F.
v2 is a random direction in 5-space. 0.0~v2 is a random direction in 6-space (thus a potential impulse vector) that's orthogonal to I1 since it has a zero component in the 1st component. A simpler (and equivalent) way of looking at this would be
compute v2=%ranmat(6,1) ;* Draw a random 6-vector
compute v2(1)=0.0 ;* Zero the 1st component
compute v2=v2/sqrt(%normsqr(v2)) ;* Normalize to unit length
compute v=i2=f*v2 ;* Transform to impulse vector
Posted: Fri Mar 13, 2009 4:24 am
by lhlee0506
Tahnk you for your kind instruction.
But when I ran this program as following, it showed the error message like
## SX11. Identifier P is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>> compute v=i1=p*v<<<<
## SX11. Identifier GOODRESPA is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>> dim goodrespa(<<<<
why is that? did I miss any point?
If I could have your instruction, i will be very grateful.
* Replication File for Uhlig (2005), "What are the effects of monetary policy on output?
* Results from an agnostic identification procedure." Journal of Monetary Economics, 52, pp
* 381-419. Pure sign restriction approach
open data uhligdata.xls
calendar 1965 1 12
data(format=xls,org=columns) 1965:01 2003:12 gdpc1 gdpdef cprindex totresns bognonbr fedfunds
set gdpc1 = log(gdpc1)*100.0
set gdpdef = log(gdpdef)*100.0
system(model=varmodel)
lags 1 to 12
estimate(noprint)
dec vect[strings] vl(6)
compute vl=||'real GDP','GDP price defl','Comm. Price Ind.','Fed Funds Rate','Nonborr. Reserv.','Total Reserves'||
* n1 is the number of draws from the posterior of the VAR
* n2 is the number of draws from the unit sphere for each draw for the VAR
* nvar is the number of variables
* nstep is the number of IRF steps to compute
* KMAX is the "K" value for the number of steps constrained
compute n1=200
compute n2=200
compute nvar=6
compute nstep=60
compute KMAX=5
compute sxx =%decomp(%xx)
compute svt =%decomp(inv(%nobs*%sigma))
compute ncoef =%rows(sxx)
compute wishdof=%nobs-ncoef
dec rect ranc(ncoef,nvar)
* Most draws are going to get rejected. We allow for up to 1000
* good ones. The variable accept will count the number of accepted
* draws. GOODRESP will be a RECT(nsteps,nvar) at each accepted
* draw.
declare vect[rect] goodresp(1000)
declare vector ik a(nvar)
compute accept=0
infobox(action=define,progress,lower=1,upper=n1) 'Monte Carlo Integration'
do draws=1,n1
* responses.
compute sigmad =%ranwisharti(svt,wishdof)
compute swish =%decomp(sigmad)
compute ranc =%ran(1.0)
compute betau =sxx*ranc*tr(swish)
impulse(noprint,model=varmodel,decomp=swish,results=impulses,steps=nstep)
* orthogonal components.
do subdraws=1,n2
compute p=inv(sigmad)
do k=1,KMAX+1
branch 105
end do k
* factor "f").
do k=1,KMAX+1
branch 105
end do k
if accept>=1000
break
:105
end do subdraws
if accept>=1000
break
infobox(current=draws)
end do draws
infobox(action=remove)
clear upper lower resp
spgraph(vfields=3,hfields=2,hlabel='Figure 6. Impulse Responses with Pure-Sign Approach')
do i=1,nvar
compute minlower=maxupper=0.0
smpl 1 accept
do k=1,nstep
set work = goodresp(t)(k,i)
compute lower(k)=frac(1)
compute upper(k)=frac(2)
compute resp(k)=%avg(work)
end do k
smpl 1 nstep
graph(ticks,number=0,picture='##.##',header='Impulse Responses for '+vl(i)) 3
# resp
# upper / 2
# lower / 2
Posted: Fri Mar 13, 2009 10:23 am
This is the full running program from which the code above was taken. It uses different names for a few of the matrices than the Uhlig example, hence the confusion. The
P in this is the same as the
SWISH in your program.
OPEN DATA fiscal.RAT
CALENDAR(q) 1980
ALL 2005:04
compute missc=1.0e+32
DATA(FORMAT=RATS,missing=missc) / GDP GOVE DEFLA CRUDE INT M1
set gdpc1 = log(gdp)*100.0
set gdpdef = log(defla)*100.0
set cprindex = log(crude)*100.0
set bognonbr = log(m1)*100.0
set eerr = log(gove)*100.0
variables gdpc1 gdpdef cprindex int bognonbr gove
lags 1 to 4
compute vl=||'real GDP','GDP price defl','Comm. Price Ind.',$
'Bank Rate','Money Stock M1','Real Effective Exchange Rate'||
compute n1=200
compute n2=200
compute nvar=6
compute nstep=40
compute KMAX=1
dec symm s(6,6)
dec vect v1(6) ;* For the unit vector on the 1st draw
dec vect v2(5) ;* For the unit vector on the 2nd draw
dec vect v(6) ;* Working impulse vector
* draw.
declare vect[rect] goodrespa(1000)
source forcedfactor.src
compute accept=0
do draws=1,n1
* responses.
compute p =%decomp(sigmad)
compute betau =sxx*ranc*tr(p)
* This is changed to unit shocks rather than orthogonalized shocks.
impulse(noprint,model=varmodel,decomp=%identity(6),results=impulses,steps=nstep)
do subdraws=1,n2
compute v=i1=p*v1
do k=1,KMAX+1
branch 105
end do k
* factor "f").
do k=1,KMAX+1
branch 105
end do k
if accept>=1000
break
:105
end do subdraws
if accept>=1000
break
end do draws
spgraph(vfields=3,hfields=2,hlabel='Impulse Responses with Pure-Sign Approach',subhea='Italy')
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
graph(pattern,ticks,number=0,picture='##.##',header='Impulse Responses for '+vl(i)) 3
# resp
# upper / 2
# lower / 2
Posted: Wed Mar 18, 2009 12:54 pm
by lhlee0506
How do we show the impluse response of shock seperately in your 2-shocks case?
and how to show the value of impluse response to allow us calculate the impacr multipliers?
Many thanks for your helps.
Posted: Wed Mar 18, 2009 4:52 pm
This is a snippet out of the earlier program. It defines both goodresp, which are the responses to the accepted first schocks, and goodrespa which are the responses to the accepted second shocks. (The pair has to pass all tests in order to get there). If you just take the graphing code later and do the same thing with "goodrespa" replacing "goodresp", you'll get the responses to the second shock.
The impact multipliers are just the 1st entries of the goodresp's. goodresp(d)(1,j) is the impact response of variable "j" to the first shock for accepted draw "d", and goodrespa(d)(1,j) is the same for the second shock.
Posted: Fri Mar 20, 2009 7:20 am
by lhlee0506
Thank you for your kind instruction; I have successful modified my code.
But there is another confusing problem that the result seems not very stable.
When I run the code in second time, monete carlo integration will result in different impulse response graphs.
How to solve this problem?
If I wanna do further variation such as identify a year delayed shock, how do I reach it?
I will be very grateful to have your general response.
Posted: Fri Mar 20, 2009 10:41 am
Regarding the instability, you may need to send us the code and data (to
support@estima.com). However, I'm not surprised that it might not behave well. You might want to look at what percentage of draws end up working. I'm guessing that it could be quite small.
While it's possible to set this up to hit a true zero at some point beyond period 0 (you can construct a restriction matrix based upon the period "d" responses), I'm not sure that that's likely to be a fruitful exercise. After all, big positive at d-1, 0 at d, big positive at d+1 and big positive at d-1, 0 at d, big negative at d+1 would both pass, even though they're clearly very different. Since you don't have enough freedom to force 0's from d on, just hitting the one point doesn't really identify the behavior very well.
It's possible that you really should be looking at conditional forecasting, which uses restrictions at shocks at multiple steps to constrain the behavior of the data going forward.
Re: Identifying VARs with sign restrictions -- multiple shocks
Posted: Fri Mar 27, 2009 4:54 am
by fabio fornari
Hi Tom
thanks for the extension of the sign restriction to 2 impulse responses.
One question. I have three shocks to identify, then I can simply extend the process you did?
That is for the third shocks i could
comp v3 = %rannmat(whatever)
and then
comp v3(1) = 0
comp v3(2) = 0
and finally comp v=i3=f*v3 where f comes from forcefactor (the same f i used to identify the first ortghoonal complemet of i1, as called in your code)?
Thanks a lot for support.
F
Posted: Fri Mar 27, 2009 9:20 am
That's correct. This is a (standalone) example which shows the process of drawing multiple orthogonal shocks. (It's abstracted from the process of determining whether the shocks actually meet your criteria).
Note that this uses the %RANSPHERE function that was introduced in version 6.35 precisely to simplify the process for drawing random directions in N space. v=%RANSPHERE(n) is the equivalent of v=%RANMAT(n,1),v=v/sqrt(%normsqr(v))
dec symm s(4,4)
dec vect v(4)
compute s=%ranwishart(4,10.0)
compute p=%decomp(s)
* Draw an impulse vector
compute v=%ransphere(4)
compute i1=p*v
* Do a forcedfactor
@forcedfactor(force=column) s i1 f
* Draw an impulse vector from the span of the last three columns
compute v=%ransphere(3)
compute i2=%xsubmat(f,1,4,2,4)*v
* Do a forced factor with i1/i2
@forcedfactor(force=column) s i1~i2 f
* Draw an impulse vector from the span of the last two columns
compute v=%ransphere(2)
compute i3=%xsubmat(f,1,4,3,4)*v
* This will give a complete factorization of f
@ForcedFactor(force=column) s i1~i2~i3 f
Posted: Fri Mar 27, 2009 9:27 am
There's an article in the forthcoming newsletter on this very topic. See
http://www.estima.com/newslett/March2009RATSLetter.pdf
