@MVGARCHFore.src
Posted: Fri Sep 19, 2014 7:56 am
I am using @MVGARCHFore.src with mv=standard to get about 10,000 one step ahead forecasts. The code works fine for the first 3000 forecasts and then gives the following error message:
## MAT2. Matrices with Dimensions 3 x 3 and 0 x 1 Involved in * Operation
Error was evaluating entry 3529
The Error Occurred At Location 2062, Line 97 of MVGARCHFORE
Called From Location 188, Line 4 of loop/block
When mv=vech or dcc the same error message occurs after 5000 or 900 forecasts respectively. I have checked and I do not think there is a problem with the data. Can you suggest a way to address this?
Also, I understand @MVGARCHFore.src cannot be used with an asymmetric model. I tried using @mvgarchtovech.src (which accepts asymmetry) and then @MVGARCHFore.src but it did not work. Are there any alternative ways to obtain the forecasts with asymmetry?
Many thanks
Many thanks
