Gibbons, Ross and Shanken (1989) test
Posted: Sun Oct 12, 2014 8:13 am
I am trying to implement the Gibbons, Ross and Shanken (1989) test "A Test of Efficiency of a Given Portfolio", Econometrica vol.57, pp.1121-1152 (the paper can be found here: http://home.business.utah.edu/finmll/fi ... en1989.pdf). This test is widely used for linear asset pricing models. Specifically, I would like to test that the alphas (intercepts) in a linear single or multiple factor asset pricing model (CAPM, Fama-French three factor) are jointly zero. The GRS test is essentially a joint exclusion test for the alphas. Its distrbution is chi-squared (asymptotically) or is F-distributed in small smaples.
My question is the following: If I estimate a Seemingly Unrelated Regressions system with the excess returns on 25 portfolios as dependent variables, is there any way to test a joint exclusion restrction for all the intercepts in the SUR system in one go (using, for example, TEST or RESTRICT)? That would essentially amount to the asymptotic version of the test. Or, would I have to follow consumer.RPF to do that (use NLSYSTEM)? and if I go with the second approach (NLSYSTEM), how do I obtain the test statistic?
