extending uhlig sign restriction model to 7 var.
Posted: Wed Feb 18, 2009 6:28 am
by bhupal
Replication File for Uhlig(2005), "What are the effects of monetary policy on
* output? Results from an agnostic identification procedure", Journal of Monetary
* Economics, 52, pp 381-419. Pure sign restriction approach
I make the following changes in the standard codes (given below) to extend it to 7 variables from 6 variable model.
compute nvar=7
dec vect[strings] vl(7)
compute vl=||"real GDP","GDP price defl","Comm. Price Ind.","Fed Funds Rate","Nonborr. Reserv.","Total Reserves","exchnage rate"||
But I get impulse response and faction explained overlapping on a single graph for variable 6 and 7. If I extend for 8 variables, I get IRF and fraction explained for variable 6,7 and 8 on a single graph.
I would like to know whether I have to make any other change in the codes.
many thanks in advance.
Bhupal
open data uhligdata.xls
calendar(m) 1965:1
data(format=xls,org=columns) 1965:1 2003:12 gdpc1 gdpdef cprindex totresns bognonbr fedfunds
set gdpc1 = log(gdpc1)*100.0
set gdpdef = log(gdpdef)*100.0
system(model=varmodel)
lags 1 to 12
estimate(noprint)
dec vect[strings] vl(6)
compute vl=||"real GDP","GDP price defl","Comm. Price Ind.","Fed Funds Rate","Nonborr. Reserv.","Total Reserves"||
* n1 is the number of draws from the posterior of the VAR
* n2 is the number of draws from the unit sphere for each draw for the VAR
* nvar is the number of variables
* nstep is the number of IRF steps to compute
* KMAX is the "K" value for the number of steps constrained
compute n1=200
compute n2=200
compute nkeep=1000
compute nvar=6
compute nstep=60
compute KMAX=5
compute sxx =%decomp(%xx)
compute svt =%decomp(inv(%nobs*%sigma))
compute ncoef =%rows(sxx)
compute wishdof=%nobs-ncoef
dec rect ranc(ncoef,nvar)
* Most draws are going to get rejected. We allow for up to nkeep good ones. The
* variable accept will count the number of accepted draws. GOODRESP will be a
* RECT(nsteps,nvar) at each accepted draw.
declare vect[rect] goodresp(nkeep) goodfevd(nkeep)
compute ones=%const(1.0)
compute accept=0
infobox(action=define,progress,lower=1,upper=n1) "Monte Carlo Integration"
do draws=1,n1
* responses.
compute sigmad =%ranwisharti(svt,wishdof)
compute swish =%decomp(sigmad)
compute ranc =%ran(1.0)
compute betau =sxx*ranc*tr(swish)
impulse(noprint,model=varmodel,decomp=swish,results=impulses,steps=nstep)
gset irfsquared 1 1 = %xt(impulses,t).^2
* orthogonal components.
do subdraws=1,n2
compute a=%ran(1.0),a=a/sqrt(%normsqr(a))
* Check that the responses have the correct signs for steps 1 to KMAX+1
* (+1 because in the paper, the steps used 0-based subscripts, rather than
* the 1 based subscripts used by RATS).
do k=1,KMAX+1
compute ik=%xt(impulses,k)*a
if ik(4)<0.or.ik(3)>0.or.ik(2)>0.or.ik(5)>0
branch 105
end do k
* This is an accepted draw. Copy the information out. If we have enough
* good ones, drop out of the overall loop.
compute accept=accept+1
dim goodresp(accept)(nstep,nvar) goodfevd(accept)(nstep,nvar)
ewise goodresp(accept)(i,j)=ik=%xt(impulses,i)*a,ik(j)
ewise goodfevd(accept)(i,j)=ik=(irfsquared(i)*(a.^2))./(irfsquared(i)*ones),ik(j)
if accept>=nkeep
break
:105
end do subdraws
if accept>=nkeep
break
infobox(current=draws)
end do draws
infobox(action=remove)
clear upper lower resp
spgraph(vfields=3,hfields=2,footer="Figure 6. Impulse Responses with Pure-Sign Approach")
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodresp(t)(k,i)
compute lower(k)=frac(1)
compute upper(k)=frac(2)
compute resp(k)=%avg(work)
end do k
smpl 1 nstep
graph(ticks,number=0,picture="##.##",header="Impulse Responses for "+vl(i)) 3
# resp
# upper / 2
# lower / 2
spgraph(vfields=3,hfields=2,footer="Figure 8. Fraction of Variance Explained with Pure-Sign Approach")
do i=1,nvar
compute minlower=maxupper=0.0
smpl 1 accept
do k=1,nstep
set work = goodfevd(t)(k,i)
compute upper(k)=frac(3)
compute resp(k)=frac(2)
end do k
smpl 1 nstep
graph(ticks,number=0,min=0.0,picture="##.##",header="Fraction Explained for "+vl(i)) 3
# resp
# upper / 2
# lower / 2
smpl
Re: extending uhlig sign restriction model to 7 var.
Posted: Wed Feb 18, 2009 9:12 am
bhupal wrote:Replication File for Uhlig(2005), "What are the effects of monetary policy on
compute nvar=7
Bhupal
The two "SPGRAPH" instructions are set to allow for 6 panes. (3 vertical x 2 horizontal). You'll need to change both of those to allow for more slots; probably going to vfields=4,hfields=2
do i=1,nvar
   smpl 1 accept
   do k=1,nstep
   end do k
   smpl 1 nstep
   # resp
   # upper / 2
   # lower / 2
