evaluation of forecasts under VAR
Posted: Wed Aug 12, 2015 11:14 pm
In case the variables in the model have a unit root, following Sims (1980) and Doan (1990), we can estimate VAR in levels in case a cointegrating relationship exists. Then VAR will have variables with unit roots. Is it then possible to use the Modified DM test and the encompassing tests due to Clarke et. al (2001,2005)(for nested models) or do these tests work only in the absence of unit roots in the VAR. The papers that I have read use these tests for VAR with stationary variables.
In the case of BVAR, even if the variables are nonstationary, they can continue to be specified in levels in a BVAR model because as pointed out by Sims et. al (1990, p.136) ‘……the Bayesian approach is entirely based on the likelihood function, which has the same Gaussian shape regardless of the presence of nonstationarity, [hence] Bayesian inference need take no special account of nonstationarity’. Furthermore, Dua and Ray (1995) show that the Minnesota prior is appropriate even when the variables are cointegrated. Can we use the Clarke et. al tests(2001,2005) for nested BVAR models?
Are there any other tests apart for the encompassing tests literature that can be used to compare the forecasting performance of alternative VAR and BVAR models that are nested
