suppressing Error Messages
Posted: Mon Aug 17, 2015 5:21 am
by Gilbril
Dear Tom, I do have to read in a quite large Excel-Database which is actualized frequently. The name of the series is in the first column, followed by descriptions, an the data starts in column 14.
Rats can read in the Excel file, but produces an enormous amount of error Messages (due to the descriptions in between and the data format which is m1.99). I can not change the structure of the database. Is there any possibility to delete the error messages in the output window? Up to now i do this manually.
Thanks a lot
gilbril
Re: suppressing Error Messages
Posted: Mon Aug 17, 2015 7:40 am
Can't you use the TOP, LEFT, BOTTOM and RIGHT options on DATA to skip around the non-data information?
Posted: Tue Aug 18, 2015 1:58 am
by Gilbril
The Problem is that I neeed the first column to name the series. Therefore I don't know how to skip around without omitting the first column.
gilbril
Posted: Tue Aug 18, 2015 9:59 am
It sounds like you need
ORG=ROWS,LEFT=14,NOLABELS
then list the series names on the DATA instruction (in order).
