How to save coefficients and residuals in the loop?
Posted: Fri Sep 11, 2015 12:29 pm
by yelena
Dear Tom, I am trying to run a loop for several series. But it seems that in my code the residuals are overwitten with the last series. How to save each residuals (resids) and coefficients (coef) for each series in the loop separately (in a matrix or so)? The incorrect program is attached:
dofor i = DEPENDENT FED LIBOR12 RGDP UR CPI TR3M TR2Y TR5Y TR10Y BAA MORT SP500 NCREIF CRE HPI $
OIL VOL NGDP BAASPREAD TERM SLOPE
linreg(robusterrors) DEPENDENT sambeg samend resids coef
# CONSTANT i
end dofor
Re: How to save coefficients and residuals in the loop?
Posted: Fri Sep 11, 2015 1:15 pm
What are you planning to do with them? I assume you want 22 sets of each at the end. But what are you doing once you have them?
Posted: Fri Sep 11, 2015 1:44 pm
by yelena
I have a to have 22 linear regressions for each of the series and report coefficients and residuals for each regression.
Posted: Fri Sep 11, 2015 1:54 pm
Report how?
Posted: Fri Sep 11, 2015 1:55 pm
by yelena
In Series Window I have to see the residuals for each series and I'd prefer to have coefficients for a constant and slope for each series as well, possibly in a nice matrix form. Or if not possible, just to see them in a Series Window.
Posted: Fri Sep 11, 2015 2:58 pm
   # CONSTANT i
end dofor
There's something wrong with the loop logic, since you have DEPENDENT regressed on itself in the first regression.
The quick way to get those into separately named series is to use %S and %L, as in
linreg(robusterrors) DEPENDENT sambeg samend %s("R_"+%l(i)) %s("C_"+%l(i))
which will create R_FED, C_FED series when FED is the explanatory variable, etc. You might want to look into the REPORT instruction for handling the coefficients---it wouldn't be hard to write this to generate a table with the coefficients.
Posted: Fri Sep 11, 2015 6:20 pm
by yelena
Thank you very much. It works now! Great!
One more question: since these loop was after many other loops in the code, the error terms and coefficients are not marked from 1 - 22. Do you know what causes it? Can we somehow to force it run from 1 - N of linear regressions.
Posted: Fri Sep 11, 2015 7:20 pm
Did you write %s("R_"+%l(i)) (as I wrote) or %s("R_"+i)? The former uses the labels, the latter just uses the sequence number.
Posted: Sat Sep 12, 2015 10:08 am
by yelena
Oops. My faults. Exactly, I used %("R_" +%(i)). Thank you very much.
