Simple forecasting model sets all series to the last series
Posted: Thu Oct 01, 2015 6:24 pm
I'm implementing a simple forecasting model where series are expected to grow at their average growth rate over the estimation period. (This could be done in a much simpler fashion than the way I did it below, but for the sake of learning the RATS language, I'm trying to understand why this code exhibits the behaviour it does).
This code
sets GDPH and CDH to the average growth rate of the last series in the loop, in this case CDH:
I think I've narrowed the problem down to this line
but different variations on casting "s" and %s(mean_growth) don't solve the problem. It seems to be some mistake in the lag s{1}, because whatever value I multiply that by gets used for all the forecasting periods. If I use %s(mean_growth), it's the mean growth of the last series in the loop, but if I choose some arbitrary value like 1.0, then all the forecasted periods are set to 1.0 instead.
As I said, I'll just use this code in the project itself:
since the use of the FORECAST instruction is overkill here, but I'd like to learn the cause behind this error.
This code
calendar(q) 1947 1
compute begin_samp = 1969:1
compute end_samp = 2012:4
compute end_fcast = 2015:4
open data "data.csv"
data(format = cdf, org = columns) begin_samp end_samp $
gdph cdh
close data
declare hash[frml] ids
smpl begin_samp end_samp
dofor s = gdph cdh
compute growth = %l(s) + "_growth"
compute mean_growth = %l(s) + "_mean_growth"
set %s(growth) = s{0} / s{1}
statistics(print) %s(growth)
set %s(mean_growth) begin_samp end_fcast = %mean
frml(identity) ids(%l(s)) s = s{1} * %s(mean_growth)
end dofor s
group mdl ids("gdph")>> gdph ids("cdh")>> cdh
forecast(model = mdl, from = end_samp+1, to = end_fcast, print)
ENTRY GDPH CDH GDPH_GROWTH GDPH_MEAN_GROWTH CDH_GROWTH CDH_MEAN_GROWTH
2012:02 15500.200000000 1300.8000000000 1.002781875113 1.006964245134 1.005565862709 1.01296758509
2012:03 15614.400000000 1311.2000000000 1.007367646869 1.006964245134 1.007995079951 1.01296758509
2012:04 15761.500000000 1324.6000000000 1.009420791065 1.006964245134 1.010219646126 1.01296758509
2013:01 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
2013:02 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
2013:03 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
2013:04 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
2014:01 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
2014:02 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
2014:03 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
2014:04 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
2015:01 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
2015:02 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
2015:03 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
2015:04 1.012967585 1.0129675851 NA 1.006964245134 NA 1.01296758509
calendar(q) 1947 1
gdph cdh
close data
dofor s = gdph cdh
set s end_samp+1 end_fcast = s{1} * %mean
end dofor s
print end_samp-2 end_fcast
