Why Different Results? of Built-in and Frml commands
Posted: Sat Oct 03, 2015 3:34 am
Hello Dear Tom,
I am working on writing a codes for different models of financial time series that was provided built-in in the RATS. I try to do this because I need some modification in the variance equation of these models (Univarite and Multivariate) so that I will be able to introduce dummies in the variance equation. If I includes these dummies in variance equation using Xreg option it will introduce these dummies in both equations of volatility. I need different dummies in different equation (for example Mensi at el (2015) in which they introduce dummies for structural variance break). I did the coding by myself and compare the result of my codes (without dummies) with built-in code for verification. I did coding of EGARCH model of Nelson, VARMA-GARCH of McAller and EGRACH model of Koutmos. When I estimate models with my codes and buil-in commands, the results are different even though the likelihood is almost identical. This discrepancy in results mainly in the constant of variance equation(s) and coefficients of spillover effect (multivariate models). I have used same data (d-spcscointc.txt file of Tasy Book) for the estimation of these models. The results and codes are given below for your expert opinion. Kindly guide me so that I will be able to get identical estimates of my models with my codes and built-in commands.
EGARCH Models codes and results
The codes
The Results
By looking at the results: likelihood value in both results are nearly same. coefficients of mean equation are identical. Come to the variance equation, coefficient # 4, 5, and 6 are nearly same in both codes but look at constant of variance equation in both they are significantly different from each other.
Now the codes and results of EGARCH model of Koutmos
The codes
The Results
Look at the results likelihood value and mean equations results are same in both results. The only difference in results at constant of variance equations and spillover effect. constants of variance equation not only different in values but in sign as well. The spillover effects are in reverse order in both codes. for example coefficient 10 of my codes is equal to coefficient 11 of built-in codes and also coefficient 11 of my codes is equal to coefficient 10 of built-in codes.
I am facing the same issue with VARMA GARCH model. Now what I should do to over come this issue?
Regards, Irfan Awan
The codes
open data d-spcscointc.txt
data(format=free,org=columns,top=2) 1 2275 sp500 cisco intel
set r1 = sp500
set r2 = cisco
* This replaces your initialization of variances to zero.
stats(noprint) r1
set h = %variance
nonlin c0 c1 c a b d
frml e = R1(t)-c0-c1*R1(t-1)
frml var = c+a*(abs(e(t-1)/sqrt(h(t-1)))-sqrt(2/%pi))+b*log(h(t-1))+d*(e(t-1)/sqrt(h(t-1)))
frml gln = h=exp(var(t)), %logdensity(h, e)
smpl 3 2275
compute c0= .17, c1 = 0.13, c = 0.8, a = .1, b = .0003, d=-1
maximize(method=bfgh,iterations=500,rob) glnCode: Select all
GARCH(P=1,Q=1,EXP,ASYMMETRIC,rob,reg) / R1
# constant r1{1}Code: Select all
MAXIMIZE - Estimation by BFGS
Convergence in 24 Iterations. Final criterion was 0.0000032 <= 0.0000100
Usable Observations 2273
Function Value -2650.6793
1. C0 0.042971207 0.016451077 2.61206 0.00899983
2. C1 0.041454940 0.024626977 1.68331 0.09231429
3. C -0.002161605 0.004352407 -0.49665 0.61943875
4. A 0.124309653 0.028409867 4.37558 0.00001211
5. B 0.983974980 0.007608731 129.32182 0.00000000
6. D -0.074441790 0.022458964 -3.31457 0.00091784
Convergence in 25 Iterations. Final criterion was 0.0000099 <= 0.0000100
Dependent Variable R1
Log Likelihood -2651.6327
1. Constant 0.043045336 0.014425693 2.98394 0.00284567
2. R1{1} 0.041561338 0.023235316 1.78871 0.07366086
3. C -0.102111331 0.029282510 -3.48711 0.00048827
4. A 0.125353695 0.034747261 3.60758 0.00030906
5. B 0.983915225 0.008372386 117.51909 0.00000000
6. D -0.073425349 0.025383578 -2.89263 0.00382029
The codes
set r1 = sp500
set r2 = cisco
stats(noprint) r1
set h1 = %variance
stats(noprint) r2
set h2 = %variance
nonlin M10 M11 M12 M20 M21 M22 C1 C2 A11 A12 A21 A22 B1 B2 D1 D2 rho
frml e_r1 = r1(t)-M10-M11*r1(t-1)-M12*r2(t-1)
frml e_r2 = r2(t)-M20-M21*r1(t-1)-M22*r2(t-1)
frml fr1 = (abs(e_r1/sqrt(h1))-sqrt(2/%pi))
frml fr2 = (abs(e_r2/sqrt(h2))-sqrt(2/%pi))
frml z1 = e_r1/sqrt(h1)
frml z2 = e_r2/sqrt(h2)
frml var_r1 = exp(c1+a11*(fr1(t-1)+d1*z1(t-1))+a12*(fr2(t-1)+d2*z2(t-1))+b1*log(h1(t-1)))
frml var_r2 = exp(c2+a21*(fr1(t-1)+d1*z1(t-1))+a22*(fr2(t-1)+d2*z2(t-1))+b2*log(h2(t-1)))
frml gln = h1 = var_r1(t), h2 = var_r2(t), %logdensity(||h1|rho*sqrt(h1*h2),h2||,||e_r1,e_r2||)
smpl 3 2275
compute m10 = 01, m20 = .2, m11 = .03, m12 = .04, m21 = .09, m22 = .08
compute c1 = .01, c2 = .04, a11= .04, a22 = .014, a12=.08, a21=.06
compute b1 = .01, b2 = .08, d1 = .04, d2 = .08
compute rho=.08
maximize(method=bfgh,ite=500,pit=20,pmet=sim,rob) glnCode: Select all
GARCH(P=1,Q=1,MV=CC,VARIANCES=KOUTMOS,REGRESSORS,PMETHOD=SIMPLEX,PITERS=20,rob) / R1 R2
# Constant r1{1} R2{1}Code: Select all
Convergence in 41 Iterations. Final criterion was 0.0000025 <= 0.0000100
Function Value -7778.3881
1. M10 0.047121219 0.013493860 3.49205 0.00047933
2. M11 0.003150756 0.022161548 0.14217 0.88694398
3. M12 0.014972792 0.005958371 2.51290 0.01197431
4. M20 0.216337120 0.049657854 4.35655 0.00001321
5. M21 -0.037247364 0.081931155 -0.45462 0.64938420
6. M22 0.048598453 0.024417196 1.99034 0.04655380
7. C1 -0.004762401 0.004252895 -1.11980 0.26279807
8. C2 0.061290660 0.028398115 2.15827 0.03090723
9. A11 0.117066387 0.027882548 4.19855 0.00002686
10. A12 -0.004946090 0.014637982 -0.33789 0.73544288
11. A21 -0.020658764 0.018672091 -1.10640 0.26855429
12. A22 0.105050725 0.026104390 4.02426 0.00005716
13. B1 0.980705644 0.009125211 107.47211 0.00000000
14. B2 0.969549832 0.014492062 66.90213 0.00000000
15. D1 -0.541918842 0.088781796 -6.10394 0.00000000
16. D2 -1.015702303 0.221988135 -4.57548 0.00000475
17. RHO 0.519600274 0.017175700 30.25206 0.00000000
MV-CC GARCH with Koutmos EGARCH Variances - Estimation by BFGS
Convergence in 53 Iterations. Final criterion was 0.0000047 <= 0.0000100
Log Likelihood -7779.2762
Mean Model(R1)
1. Constant 0.046926041 0.010246796 4.57958 0.00000466
2. R1{1} 0.003722970 0.023917258 0.15566 0.87630072
3. R2{1} 0.015022906 0.005248749 2.86219 0.00420727
Mean Model(R2)
4. Constant 0.215835888 0.042987891 5.02085 0.00000051
5. R1{1} -0.035827949 0.072481894 -0.49430 0.62109288
6. R2{1} 0.048756093 0.023112762 2.10949 0.03490248
7. C(1) -0.094511925 0.022082230 -4.28000 0.00001869
8. C(2) -0.006249044 0.022346638 -0.27964 0.77975267
9. A(1,1) 0.117611736 0.024107562 4.87862 0.00000107
10. A(1,2) -0.020517148 0.016283699 -1.25998 0.20767628
11. A(2,1) -0.005125008 0.013020480 -0.39361 0.69386801
12. A(2,2) 0.105522682 0.025060981 4.21064 0.00002547
13. B(1) 0.980614154 0.006154526 159.33220 0.00000000
14. B(2) 0.969426894 0.013691089 70.80714 0.00000000
15. D(1) -0.537684424 0.118375654 -4.54219 0.00000557
16. D(2) -1.007991695 0.223240584 -4.51527 0.00000632
17. R(2,1) 0.519245244 0.014370774 36.13203 0.00000000
Regards, Irfan Awan
