How to perform rolling regressions in RATS
Posted: Wed Mar 25, 2009 4:28 pm
by alvarezcc
Hi!! I´d like to know if somebody knows how to perform rolling regressions with RATS. I´m trying to estimate a persistence coefficient for Costa Rica´s CPI inflation rate. I downloaded this file: rollreg.src from
http://fmwww.bc.edu/repec/bocode/r/rollreg.src but when I tried to run it it just did´nt worked. I don´t know if it is becouse of the version I´m working in RATS which is 6.3. I´d really appreciate any kind of help.
Cristian Alvarez.
Universidad de Costa Rica
Re: How to perform rolling regressions in RATS
Posted: Wed Mar 25, 2009 4:59 pm
by moderator
Try looking up "rolling regressions" in the RATS User's Guide index. You'll find references to a couple of simple examples.
There are a lot of ways to set these up depending on how you want to specify the range (e.g., if you want to loop based on the starting entry or the ending entry, if you want a moving window type regression or want a fixed starting entry, and so on), but the basic tools are pretty straightforward.
Posted: Thu Mar 26, 2009 10:44 am
You might have better luck with this. The main problem with the version posted on the web was that it appeared to be a UNIX text file, which Windows generally doesn't like.
A modernized version of the procedure is now available at:
http://www.estima.com/forum/viewtopic.php?f=7&t=741
Posted: Tue Apr 07, 2009 11:50 pm
by alvarezcc
Thanks!! But don´t you have the procedure file, I mean the .src file. If you also have an example it would be great. Thanks again!!
Posted: Wed Apr 08, 2009 10:52 am
by moderator
No, we don't have a copy of the ROLLREG.SRC file available on our website. The authors never submitted a copy to us, and we do not provides files from others as downloads without their permission.
However, Tom Doan has already posted the code here in this thread, so all you should need to do is copy and paste that into RATS and save it as a file.
Posted: Tue May 05, 2009 10:48 pm
by alvarezcc
Hi!! I have a problem trying to run the rolling regression because I don´t know how to specify the model in RATS. I´m trying to estimate this equation using the procedure that was posted previously:
π= α+β π(t-1)+δM+θε(t-1)+εt
Where:
π = Corresponds to the monthly year to year inflation rate.
M = Rate of growth of money supply.
and
ε= Regression error term.
The matter is that I don´t know how to specify this model, which is supposed to have an ARMA(1,1) structure. I´ll appreciate if someone can tell me how to do this!!
Posted: Wed May 06, 2009 1:42 pm
You can't do that with the ROLLREG procedure, since that's only for linear regressions, and, because of the lagged residual, this is non-linear.
isn't quite in the form that BOXJENK wants. (BOXJENK wants a mean model and an ARMA noise model, not a reduced form like this). The older instruction ITERATE is probably better for this type of equation:
EQUATION(AR=1,MA=1,REGRESSORS) PIEQ PI
# M
INITIAL PIEQ
ITERATE PIEQ start end
where start and end would need to change based upon the type of "roll" that you want.
Posted: Thu May 07, 2009 12:57 pm
by alvarezcc
Thanks Tom!! But I have one more doubt.How can I tell RATS using the iterate function to do rolling estimates like the ADD and MOVE options in the rollreg procedure that was posted. Or is it that I have to do all the regressions one by one? Thanks for your help!!
Cristian Alvarez C.
Posted: Sat May 09, 2009 11:25 am
That's actually all that the rollreg procedure is doing - in that case a set of linreg's. The point of the procedure is that it handles figuring out what set of regressions need to be run for a given set of options and then gives you options for the output.
Posted: Mon Jun 08, 2009 2:57 pm
by alvarezcc
Hi!! Finally, I have the persistence estimates but I obtained some AR(1) negative coefficients for a subset of the sample. Does anybody Knows how to interpret the AR(1) negative coefficients in this context?
Posted: Mon Jun 08, 2009 5:22 pm
Possibly there's rather substantial collinearity between M(t) and pi(t-1) over that period. Is the coefficient negative but not significantly so?
Posted: Mon Jun 08, 2009 10:07 pm
by alvarezcc
Thanks for your answer Tom! I have rolling window estimates for 1990:01 to 2008:12 (with 72 data points). The model is an AR(1) for monthly inflation rate with the money supply growth rate as a control variable (lagged two periods). I have two subsets of the sample where the coefficient associatted to the lagged inflation is negative. This are 1990:01 to 1992:08 and 2007:4 to 2008:12. As you can see, the negative coefficients are distributed in the beggining and the end of the entire sample. For the first subset 15.5% coefficients are significant at 10% and for the second subsample none are significant at the same level. However, this problem persists even if I remove the money supply growth rate from the right hand side of the equation. I hope this information might be usefull. Thanks again!!
Posted: Sun Nov 08, 2009 8:11 am
by shruti
hi,
Is there any way to run rolling bivariate regression with the lags of variables and estimate rolling impulse response functions??
I am trying to estimate effect of oil prices on India's GDP using a moving window of 40 quarters, but am not very successful.
Posted: Thu Nov 12, 2009 11:45 am
shruti wrote:hi,
Rolling regressions themselves are fairly easy; it's figuring out what you want as a result and organizing the saving of that. I'm not sure that rolling IRF's are going to be all that useful. They're an indirect function of the coefficients and aren't very likely to change from period to period in a fashion that is likely to be enlightening. Is there any reason not to just compare the IRF's at several samples?
Posted: Fri Nov 13, 2009 3:54 am
by shruti
Thanks for the reply,
But actually what I am trying to do is to reproduce the results of Blanchard's paper The Macroeconomic Effects of oil prices: Why are 2000s different from 1970s. In section 4 of this paper, authors did the same exercise. Please have a look:
http://www.nber.org/papers/w13368.pdf?new_window=1
