Is there a built in way to convert cards to regression lists
Posted: Thu Oct 29, 2015 1:04 pm
by macro
I wrote a simple procedure that takes a supplementary card and converts it to a regression list
procedure rlfromcards
    local equation regs
    equation regs *
    compute %rl = %rlfromeqn(regs)
so I can write code like this
@rlfromcards
# gdp{1 to 4} ffed{1 to 2} pce{1 to 4}
and convert it to a regression list that I can pass into other procedures that take a regression list. This seems like something that would be built into RATS. ENTER is certainly related to this, but it didn't seem like the way forward.
I use -rlfromcards- because I have several custom procedures that take regression lists as input, and it's helpful to build the regression list once, using the -cards- format, and then reuse it throughout the program, instead of manually specifying the -cards- format every time.
Re: Is there a built in way to convert cards to regression l
Posted: Thu Oct 29, 2015 1:39 pm
You can use a combination of the %table... and %rl... functions for that. For instance:
equation yeqn *
# y u ddp
* Co-states from measurement equation(s)
equation zeqn *
# ddp{1 to nlags} ddm{0 to nlags} constant
* Figure out the observable range
inquire(reglist) start end
# %rlfromtable(%eqntable(zeqn)) %rlfromtable(%eqntable(yeqn))
Posted: Thu Oct 29, 2015 1:57 pm
by macro
Perfect, thanks for the quick response. I always prefer a built-in way than using some home-cooked procedure. For my purposes, this
equation eq *
# gdp{1 to 4} ffed{1 to 2} pce{1 to 4} constant
compute %rl = %rlfromeqn(eq)
seems to work, since my custom procedures handle the ranges on their own.
