Size of shock in VAR
Posted: Fri Nov 06, 2015 7:25 am
by atanu
Dear Tom, and other RATS users,
Just a very simple question: in a VAR where I have calculated the impulse response functions with a one standard deviation shock; how can I modify the code to a two standard deviation shock?
Re: Size of shock in VAR
Posted: Fri Nov 06, 2015 9:19 am
Assuming you're doing standard Cholesky shocks, use FACTOR=2.0*%DECOMP(%SIGMA). If you're doing anything else, just multiply the input shocks by 2. (You can also, of course, just multiply the responses by 2).
Posted: Tue Oct 04, 2016 5:05 pm
by sebaschoo
As you suggested I used FACTOR=3.0*%DECOMP(%SIGMA) in order to compute a 3 stdv shock in the following way
impulse(model=varmodel6,steps=nsteps,results=baseirfs,noprint,factor=3.0*%decomp(%sigma))
compute shocklabels=||"Foreign Interest Rate","GDP","Inflation","House Price","Exchange Rate","Monetary Policy"||[code]
compute varlabels=||"Foreign Interest Rate","GDP","Annual Inflation","Houce Index Price","Exchange Rate","Interest Rate"||
@mcvardodraws(model=varmodel6,draws=10000,steps=35)
@mcgraphirf(shock=shocklabels,varlabels=varlabels,include=||6,2,3,4,5||,page=byshocks,model=varmodel6,$
center=input,impulses=baseirfs)[/code]
But I have a problem, I pressume the error bands don't take into account the 3 stdv shock with the code I'm using.
Could you please help me with this issue?
Thank you !!!
Posted: Tue Oct 04, 2016 5:21 pm
Changing the one-off calculation on the IMPULSE instruction will have no effect on the @MCVARDODRAWS. You'll have to change that (using an FFUNCTION option) to use the adjusted shocks.
Again, I'm not sure what the point is. Everything will just be three times what it is for a one standard deviation shock.
Posted: Tue Oct 04, 2016 5:39 pm
by sebaschoo
Thank you very much.
I just want to reflect in the model certain changes in the historical data of my country. For instance, during the final years of the 90s the interbank interest rate moved from 22.615% to 50.59% (in my data that means a 3 stdv shock aprox).
I'm quite new using RATS, I would appreciate a lot if you can help me with the FFUNCTION option in order to adjust the shocks.
Thanks a lot !!!
Posted: Tue Oct 04, 2016 7:34 pm
function ThreeX sigma model
type rect ThreeX
type symm sigma
type model model
compute ThreeX=3*%decomp(sigma)
@mcvardodraws(model=varmodel6,draws=10000,steps=35,ffunction=ThreeX)
Posted: Wed Oct 05, 2016 4:45 pm
by sebaschoo
Million thanks Tom it worked perfectly !!! :D
