Page 1 of 2
Balcilar, et al EE(2015)
Posted: Tue Nov 24, 2015 4:15 am
by n_khraief
Dear Listers,
I am trying to run the oil_stock_msvar_irf2.RPF program I have got always the same following error:
## SR3. Tried to Use Series Number 45844208, Only 5 Are Available
The Error Occurred At Location 531, Line 72 of MSSYSREGRESSION
Would you like please to help me with this.
Kind regards,
N.K
Re: Error
Posted: Tue Nov 24, 2015 8:04 am
That's not the data file that the program uses.
Re: Error
Posted: Tue Nov 24, 2015 8:57 am
by n_khraief
Thank you for your reply but I used the excel file and I got the same error message.
Re: Error
Posted: Tue Nov 24, 2015 10:11 am
1. It has nothing to do with the data file. However, I couldn't run a program which references a data file that I don't have.
2. Use a newer version of @MSSYSREGRESSION.
3. A MS model is completely inappropriate to your data. There are definitely multiple regimes, but there's nothing "Markov" about them---there's a 30 year period in the middle of the data where the oil prices are controlled.
Re: Error
Posted: Tue Nov 24, 2015 11:07 am
by n_khraief
Many Thanks Tom.
It is not my data basis, just I tried to replicate the estimation of a published paper (Energy Economics 49 (2015) 317–327) with their data basis and their program.
N.K
Re: Balcilar, et al EE(2015)
Posted: Tue Nov 24, 2015 4:53 pm
I have an e-mail in to the authors with some questions about what they did. At any rate, you need a newer version of MSSYSREGRESSION.
Posted: Wed Nov 25, 2015 1:38 am
by n_khraief
I am so grateful.
Did you mean the last version of MSSYSREGRESSION the attached file.
Kind regards and many thanks,
N.K
Posted: Sun Nov 29, 2015 10:09 pm
Yes.
Posted: Wed Dec 02, 2015 10:04 pm
A cleaned up version of the program is now posted at https://estima.com/forum/viewtopic.php?f=8&t=2536. As in the paper, this finds two regimes, one where the price of oil doesn't change, one where it does. As I said above, it's not clear that a "Markov" assumption is reasonable for that, since for about 30 years, the price of (U.S.) oil was controlled by law.
Posted: Thu Dec 03, 2015 1:21 am
by n_khraief
Thanks a lot, Tom.
Posted: Thu Dec 03, 2015 3:48 pm
by n_khraief
Dear Tom thank you for your valuable efforts.
I have a question:
Why the error:
## SR3. Tried to Use Series Number 70201344, Only 9 Are Available
repeated after the following part of program
@mssysregression(states=2,switch=ch)
# dlsp dloil
# dlsp{1 to lag} dloil{1 to lag} constant ect{1}
N.K
Posted: Thu Dec 03, 2015 4:08 pm
You're using an outdated version of the program. The whole MS suite of procedures has changed.
Posted: Mon Dec 07, 2015 2:19 am
by n_khraief
How can test for the presence of Markov assumption in time series?
N.K
Posted: Mon Dec 07, 2015 10:22 am
There really isn't a way to do that. Tests for n+1 vs n regimes are very complicated and generally not worth the effort---people typically use information criteria to compare those, though that requires that you can actually fit an n+1 regime model, which is often quite a task if n regimes are adequate as the n+1 regime model isn't identified. And I'm not sure I've ever seen a test for Markov vs some other form of switching.
Posted: Mon Dec 07, 2015 1:56 pm
by n_khraief
Many thanks Tom.
Actually, I just found this paper that developed a new test for the Markov property in time series. A Gauss code to implement
this test is available from the authors.
https://hong.economics.cornell.edu/pape ... Series.pdf
Thanks a lot Tom,
N.K
