Panel unit root test for unbalanced panel
Posted: Wed Apr 08, 2009 4:34 pm
by lis
I am a new rats user. I am trying to run the "RATS CODE FOR COINTEGRATION TESTS IN HETEROGENEOUS PANELS WITH MULTIPLE REGRESSORS" by Pedroni for an unbalanced panel. My code looks as follows below (see part of the code). The problem is now that I have a line break and obtain the following syntax error when I run Rats:
Normal Completion. Halt at XXX
## SX16. Missing Operand or Adjacent Operators
>>>>23,23,23,23,23,23,<<<<
Who can help mw out on this issue?
Thanx a lot!
Cheers,
Lisa
Part of the code:
compute Nsecs = 138 ;* cross section dimension, N
compute Tperiods = 23 ;* time series dimension, T, if balanced
compute mlag = 0 ;* largest possible value for lag truncations (0,1,2; Isa: 1-4))
compute yestrend = 0 ;* set to 1 for hetero trends, else 0
compute m = 0 ;* number of RHS regressors (2 variablen)
dec vec[series] datavec(m+1) ;* define data variables below
set datavec(1) = budget ;* LHS variable
* set datavec(2) = FFII ;* second RHS variable, and so forth
* set datavec(3) = SER ;* second RHS variable, and so forth
compute unbal = 1 ;* set to 1 for unbalanced panel, else 0
dec vec Tvec(Nsecs)
* For unbalanced panels, fill in the value below for T for each member
* in the order in which they appear in the stacked panel
* compute Tvec = ||100,100,100 ... one value for each member .... 100, ||
compute Tvec= || 23,23,23,23,23,23,14,23,23,23,23,23,23,23,23,23,23,23,23,21,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,18,
23,23,23,23,23,23,23,23,23,23,23,23,23,23,20,23,23,23,23,23,23,23,23,20,23,23,23,23,23,23,23,23,23,
|23,23,23,23,16,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,16,23,23,23,
23,23,23,23,23,23,23,23,23,23,23,23,23,23,23,19,23,23,23,23,21,20,23,19,23,23,23,22,23,23,20,23,23,||
Re: Panel unit root test for unbalanced panel
Posted: Thu Apr 09, 2009 10:13 am
You're using a rather old version of this that requires a lot of editing. Try using the newer @PanCoint procedure. That's on the distribution CD as well.
