New Series Based on an Existing Series and a Dummy Variable
Posted: Fri Dec 25, 2015 6:47 pm
by alexecon
I have a series
and would like to set a new one
using an existing dummy
How can I do this in RATS? Thank you.
Re: New Series Based on an Existing Series and a Dummy Varia
Posted: Fri Dec 25, 2015 9:25 pm
That looks like
set expanded = original(fix(dummy(t)))
Posted: Sat Dec 26, 2015 7:13 am
by alexecon
TomDoan wrote:set expanded = original(fix(dummy(t)))
For some reason that is not immediately apparent to me this sets all values of
expanded to 0 (even though
original has nonzero values).
Posted: Sat Dec 26, 2015 3:36 pm
So far as I can tell, that should work fine based upon your definition. If you do
print 1 3 original
do you get the three values that you want?
Posted: Sun Dec 27, 2015 4:26 am
by alexecon
TomDoan wrote:do you get the three values that you want?
Yes, I do get them. But I'm not sure why we are using
fix in the first place. I was expecting we may need to use a loop that takes the first value (x) from the original series and copies it in the first three rows of the expanded series, then takes the second (y) value from the original and copies it in the next four rows of the expanded and so on.
Posted: Sun Dec 27, 2015 10:00 am
FIX is necessary because dummy(t) is a REAL and you need an INTEGER for a subscript. If the setup is as you describe it, what I provided will work. If it doesn't you'll have to post the actual program that you're trying to use.
Posted: Sun Dec 27, 2015 11:32 am
by alexecon
Here is the code:
OPEN DATA "/Users/[...].xls"
CALENDAR(D) 2001:1:1
DATA(FORMAT=XLS,ORG=COLUMNS) 2001:01:01 2014:12:31 XR3M XR0 RATE3M RATE USRATE USRATE3M
* set financial openness from daily data
set devcip_d = (1+usrate3m/100)-(1+rate3m/100)*(xr0/xr3m)
set fi_d = 1/exp((abs(devcip_d)))
* series transformations (growth rates)
dofor i = XR3M to USRATE3M
compute [label] dlogs = "dl"+%l(i)
set %s(dlogs) = log(i{0}/i{1})
* stats %s(dlogs)
enddofor i
* set monthly dummy and indicator from daily data
set yymm = %year(t)*100+%month(t)
panel(group=yymm,id=yymmvalues)
* set exchange rate stability (ers)
set mysd 1 %size(yymmvalues) = %na
do i=1,%size(yymmvalues)
stats(noprint,smpl=(yymm==yymmvalues(i))) dlxr0
compute mysd(i) = sqrt(%variance)
set mysd2 = mysd(fix(yymm(t)))
set ers = 1/(1+mysd2)
The frequency of the data in memory is daily. The last bit of the code calculates 168 monthly standard deviations from the daily data. My problem is that it stacks them at the beginning of the dataset as daily observations. What I am trying to do is to "expand" them so that there are 28/29/30 or 31 (identical) observations per month. (Then I can read the data into RATS compacted by monthly average, which is the setup that I eventually want to use).
Unfortunately, the line involving
fix generates an empty series.
Posted: Sun Dec 27, 2015 12:14 pm
The problem is that the "dummy" doesn't map to 1, 2, ... as it does in the simple example. The simplest way to do this is to use the SMPL option on SET. Just
set(smpl=(yymm==yymmvalues(i))) mystd2 = sqrt(%variance)
