The STEPS instruction crashes in RATS 9, but not RATS 8.3
Posted: Thu Jan 21, 2016 10:20 am
This code
works in in RATS 8.3 Pro, but crashes RATS 9.0 Pro. Both of these versions are running on the same machine (Windows 7 x64). Was something changed in RATS between these versions that is causing this to fail? I looked in the reference manuals for each versions, and I can't find any syntax changes between versions that would cause the code to fail in 9.0.
Unfortunately, for this project, going back to RATS 8.3 isn't an option for me because I'm using some of the features that are new in RATS 9.0 (as discussed in other posts).
calendar(q) 1969 1
compute begin_samp = 1969:1
compute end_samp = 2006:4
compute max_lags = 4
open data "sandbox_data.xls"
data(format = xls, org = columns)
close data
inquire(regressorlist) begin_est end_est
# lgdpk{0 to max_lags} lcdk{0 to max_lags} ffedk{0 to max_lags}
system(model = mdl)
variables lgdpk lcdk ffedk
lags 1 to max_lags
deterministic constant
estimate(model = mdl) begin_est end_est
declare rectangular[series] residuals
steps(model = mdl, print, from = begin_est, to = end_est, residuals = residuals)
