Store correlation matrix output
Posted: Tue May 31, 2016 1:40 pm
by cyang40
I would like to store the correlation between two variables, but my following command does not do the job. Could you please direct me as to what is missing in my code? Thank you.
cmom(corr,print)
# gdp_detrend govt_detrend
compute mycorrs = %cmom(gdp_detrend,govt_detrend)
Re: Store correlation matrix output
Posted: Tue May 31, 2016 1:50 pm
You want %cmom(1,2)---the elements of the array are accessed by position, not by the variable.
Posted: Tue May 31, 2016 2:15 pm
by cyang40
I fixed the code but the output doesn't seem to exist.
cmom(corr,print)
compute mycorrs = %cmom(1,2)
print / mycorrs
## SX22. Expected Type SERIES[REAL], Got REAL Instead
>>>>print / mycorrs<<<<
Posted: Tue May 31, 2016 2:17 pm
MYCORRS is a number, not a series. Use DISPLAY, not PRINT.
Posted: Tue May 31, 2016 2:40 pm
by cyang40
Thank you for the advise. Since I have a panel data, is there a way to store the output by country? I have attempted the following procedure, and I received an error message from the system. Perhaps, I am doing this incorrectly.
do i=1,61
cmom(corr,print) i//1970:1 i//2013:1
compute mycorrs(i) = %cmom(1,2)
display mycorrs(i)
## SX11. Identifier MYCORRS is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>> compute mycorrs(<<<<
Posted: Tue May 31, 2016 3:19 pm
add
clear mycorrs
before the loop so mycorrs is recognized as a series.
Posted: Tue May 31, 2016 3:51 pm
by cyang40
This will create a vector with 1//1970:1 2//1986:1 instead of a matrix with 1//1970:1 61//2013:1. Ideally, I would like to have the value of correlation assigned to each country over time. Is there a way to modify this setting? Thank you.
Posted: Tue May 31, 2016 4:03 pm
Instead of compute do
set mycorrs i//1970:1 i//2013:1 = %cmom(1,2)
Posted: Tue May 31, 2016 4:13 pm
by cyang40
Great. Thank you very much, Tom.
