VARMA-GARCH-BEKK. no convergence in Rats 9.1
Posted: Thu Sep 15, 2016 11:30 pm
by h2do
Previously, I used Rats 8.3 and I had a convergence but no-convergence in the Rats 9.1. Could you please explain and help to get a convergence?
In addition, in other estimations, estimates from these two versions are little bit different. Why is the case?
* VARMA-MGARCH-asymmetry BEKK model.
OPEN DATA "C:\oilgas.xlsx"
CALENDAR(D) 2000:1:4
Allocate 2014:1:31
DATA(FORMAT=XLSX,ORG=COLUMNS) 2000:1:4 2014:1:31 rogindo rogmalay rogphil rogsing rogthai rogviet rogus rogasia
dec vect[series] sqrth(2)
dec vect[series] eps(2)
* VARMA (1,1)
system(model=varmah)
variables rogsing rogus
lags 1
det constant eps(1){1} eps(2){1} sqrth(1) sqrth(2)
clear(zeros) sqrth eps
* Do three iterations on the VARMA part to get an initial value for the
* covariance matrix.
do iters=1,3
   estimate(noprint,resids=resids)
   set eps(1) %regstart() * = resids(1)
   set eps(2) %regstart() * = resids(2)
end do iters
compute cv0=%sigma
garch(model=varmah,mv=bekk, variances=spillover, asymmetric,$
rvectors=rv,hmatrices=hh,presample=cv0,$
uadjust=%pt(eps,t,rv(t)),hadjust=%pt(sqrth,t,%sqrt(%xdiag(hh(t)))),$
  pmethod=simplex,piters=20)
asymmetric,
set z1 = rv(t)(1)/sqrt(hh(t)(1,1))
set z2 = rv(t)(2)/sqrt(hh(t)(2,2))
set z1sq = z1**2
set z2sq = z2**2
@bdindtests z1
@bdindtests z2
dec vect[series] zu(%nvar)
do time=%regstart(),%regend()
compute %pt(zu,time,%solve(%decomp(hh(time)),rv(time)))
end do time
*Ljung-Box Q-statistics of joint standardized residuals
@mvqstat(lag=5)
# zu
@mvqstat(lags=10)
# zu
*Ljung-Box Q-statistics of square of joint standardized residuals
@mvarchtest (lags=5)
#zu
@mvarchtest (lags=10)
#zu
@regcorrs(report,number=10) z1
@regcorrs(report,number=10) z1sq
@regcorrs(report,number=10) z2
@regcorrs(report,number=10) z2sq
corr(number=6,qstats) z1sq
corr(number=6,qstats) z2sq
Re: VARMA-GARCH-BEKK. no convergence in Rats 9.1
Posted: Fri Sep 16, 2016 10:39 am
9.1 uses better guess values for the variance constant in the BEKK model. You can get convergence in 9.1 by cutting the SIMPLEX iterations down to 10. (It actually is converged without the change, but doesn't fully pass the diagnostics for convergence).
Your "VARMA" model is grossly overparameterized. Three of the four pairs show signs of cancellation (the AR and MA are almost equal and of opposite signs) and the other one has two rather small coefficients. The near cancellation means that even fairly large simultaneous changes to both will have almost no effect on the likelihood. Fix your mean model and the model will work better.
Posted: Tue Sep 20, 2016 9:50 pm
by h2do
Thank you very much for your prompt response and advice. I'd like to eliminate autocorrelation in residual at 5% up to lag 5 so I add some AR and MA terms that could make overparameterization. Could you please suggest how could I fix the mean model?
In addition, I ran the same model for another series but It could not converge although I set iteration=10 or, 5, or remove "symmetric". You can see that I tried with 4 different VARMA models. The data is the same as the file I uploaded in my first post.
OPEN DATA "C:\BasicM.xlsx"
Allocate 2014:1:31
* VARMA (1,1)
variables rogindo rogus
lags 1
* VARMA (2,1)
lags 1 2
* VARMA (1,2)
variables rogindo rogUS
lags 1
det constant eps(1){1} eps(2){1} eps(1){2} eps(2){2}sqrth(1) sqrth(2)
* VARMA (2,2)
lags 1 2
do iters=1,3
end do iters
compute cv0=%sigma
asymmetric,
set z1sq = z1**2
set z2sq = z2**2
@bdindtests z1
@bdindtests z2
end do time
@mvqstat(lag=5)
# zu
@mvqstat(lags=10)
# zu
#zu
#zu
Posted: Wed Sep 21, 2016 11:51 am
  1. Why are you only looking at VARMA models for the mean? It's the "MA" in the VARMA that causes the parameterization problems. I'm not sure I'm ever seen a VARMA-GARCH model where there was any compelling reason to do a VARMA rather than a simpler VAR, other than to do something different.
  2. With 3500+ data points, you are unlikely to ever come up with a mean model which passes a Q test at even the .01 level. If you look, you'll see that the correlations themselves are trivially small---they're only "significant" because of the huge number of data points.
Posted: Wed Sep 21, 2016 11:51 pm
by h2do
Dear TomDoan
Thank you very much for your reply.
Best regards,
h2do
