how to detrend a series?
Posted: Sat Nov 19, 2016 1:24 am
by applej
I want see the deviation from trend of my interested series, RRG. Thus, I want to detrend it first. My code is written as:
linreg rrg 1968:5 2014:12
# constant t
But I got error: ## SR3. Tried to Use Series Number 39, Only 32 Are Available
It would be good to know any of your suggestions.
Thank you,
J
Re: how to detrend a series?
Posted: Sat Nov 19, 2016 8:21 am
Do
set trend = t
and use TREND (not T) in the regression. T is a reserved variable used as a entry pointer in expressions.
You could also just do FILTER with the option REMOVE=TREND.
Posted: Mon Nov 21, 2016 5:55 pm
by applej
TomDoan wrote:Do
set trend = t
Thank you for the above comments. :) I did the following and want to get the fitted dependent variable. :
lingreg rlogg 1968:4 2014:12
# constant trend
set rloggfit %regstart() %regend = %beta(1) + %beta(2)*trend
However, I got the error:
## SX22. Expected Type SERIES[REAL], Got RECTANGULAR[REAL] Instead
>>>>set loggfit <<<<
I wonder why it got "RECTANGULAR[REAL]"?
Posted: Mon Nov 21, 2016 7:27 pm
applej wrote:
TomDoan wrote:Do
set trend = t
# constant trend
>>>>set loggfit <<<<
First, you can just do
prj rloggfit
to get the fitted values from the regression (any LINREG). The line you're showing as producing an error is different from the one that you showed originally, so I don't know if you use loggfit in some other way.
