DSGE-VAR implementation in RATS
Posted: Thu Feb 16, 2017 5:53 pm
by BinhPham
There is another question about DSGE-VAR. To my understanding, DSGE-VAR is that DSGE model has been solved via DSGE instruction (in RATS) to obtain matrix A and F in state-space form. The next step is to use procedure varfromdlm to have the corresponding VAR model. Is it right?
Thanks in advance,
Re: DSGE-VAR implementation in RATS
Posted: Mon Feb 20, 2017 3:44 pm
I've seen the phrase used in at least two ways---either as you describe (which generates the VAR coefficients from the covariance generated by a DSGE solved out to state-space form) or as a VAR estimated from the data with a prior derived from a DSGE.
Posted: Tue Feb 21, 2017 4:10 am
by BinhPham
Thanks for your reply. Could I have an example code for any DSGE-VAR model (an replication work) that you already have ?
Thanks in advance,
Posted: Tue Feb 21, 2017 12:52 pm
To be honest, I don't have any.
