BJAUTOFIT issues
Posted: Sun Feb 19, 2017 12:37 am
by ksternbe
I am trying to run BJAUTOFIT procedures to help select a model for my series.
When I run the code below I don't get an error message but RATS does not provide any output. It simply begins to RUN for 15+ minutes and then crashes.
CALENDAR(M) 1984:1
DATA(FORMAT=FRED) * 2017:12 INDPRO
ALLOCATE 2017:12
SET LOGPRO = log(INDPRO)
*Run a BJAUTOFIT
SOURCE "Macintosh HD/Applications/RATS 9.1 Classroom/Procedures/BJAUTOFIT.src"
@BJAUTOFIT(PMAX=10,QMAX=10,CRIT=AIC) LOGPRO * 2015:12
@BJAUTOFIT(PMAX=10,QMAX=10,CRIT=SBC) LOGPRO * 2015:12
Any suggestions to deal with this issue?
Thank you.
Re: BJAUTOFIT issues
Posted: Sun Feb 19, 2017 12:07 pm
Are you sure it's with the BJAUTOFIT? The DATA instruction is pulling data off the Internet, and is a more likely place for the program to get stuck.
However, you didn't difference an obviously non-stationary series, so a lot of the models won't fit well at all (the pure MA's for instance can't explain the rather steady trend).
Posted: Sun Feb 19, 2017 6:13 pm
by ksternbe
I know that it is not the DATA portion of the code. In my series window I can see that my data comes in successfully. It could be an incompatible series, but I would expect an error message instead of just a 20 minute run time and then a software crash?
Thank you for your suggestions.
Posted: Sun Feb 19, 2017 11:23 pm
by ksternbe
You were right, it worked after I took the logged first difference of the series.
Thanks again!
