MCMC of a Volatility-only MS
Posted: Tue Feb 28, 2017 8:09 am
I'm going through example 8.3 in the Switching Models Workbook and have a couple of queries:
1. The 3x1 vector NUPRIOR is filled with fours. In the workbook you write:
2. In my estimations of a two regime example, the elements of P tend to be (too) close to the priors I have chosen in the 2x2 gprior vector (even when ndraws is very large). Do you have any ideas about why this may be the case?
Thank you.
Could you please explain why there are 4 degrees of freedom in this example?The second stage in this requires the degrees of freedom for the prior for each component (the NUPRIOR vector), which is 4 for all regimes in our example.
Thank you.
