chart shading and color
Posted: Thu Mar 02, 2017 4:07 pm
by tclark
I would like to create a chart with NBER recessions shaded and some other dates indicated by vertical lines. Although I can do that simply with the SHADING and GRID options, the default use of gray for the former and black for the latter makes things hard to distinguish. Can you suggest a good way to control the color of either the shading or the vertical grid lines to make them easier to distinguish? Thanks very much.
Re: chart shading and color
Posted: Fri Mar 03, 2017 10:03 am
Unfortunately, both of those are set to use grayscale rather than color. You can alter the level of gray in either (it's fill pattern 0 for the shading), but not the color. We can put that on the wish list.
Posted: Fri Mar 03, 2017 11:44 am
What were you thinking of doing if it were possible?
Posted: Sat Mar 04, 2017 4:31 pm
by tclark
For the chart I have in mind, with NBER shading and vertical lines marking some other dates of interest (specifically, the uncertainty events denoted in some of the work by Nick Bloom and others; some of these events fall in recession periods), what I am guessing would be most visible would be to keep the existing gray shading for the recessions and allow a color (e.g., red for visibility) for the grid lines of the other dates to be marked.
Posted: Fri Mar 17, 2017 12:20 pm
I can add options to GRPARM to change the patterns for the grid lines and background shading. However, that idea works a lot better in color than in B&W:
test grid lines color.PDF
Color version
(7.37 KiB) Downloaded 844 times
test grid lines bw.pdf
B&W version
(7.38 KiB) Downloaded 838 times
I'm not sure how to render that in B&W without it either looking odd (as above) or getting back to the original problem.
Posted: Fri Mar 17, 2017 2:08 pm
by PeterF
Hello Tom,
from my point of view, options at GRPARM for setting the color of grind lines and the shaded area would be a perfect enhancement. Especially for presentations, those options would be a great plus.
Best regards
Peter
Posted: Fri Mar 17, 2017 8:49 pm
by tclark
Tom -- Thanks very much for that. The color works, as you suggest. The B&W is of course harder to make work.
