Estimation of MRR (1997) model with GMM
Posted: Fri Apr 14, 2017 4:14 pm
I am trying to replicate the results of T. Clifton Green (2004), Journal of Finance, Vol 59, No 3.
Economic news and the impact of trading on bond prices. I am trying to estimate equation 2 in his paper.
Green's model is based on Madhavan, Richardson, and Roomans (1997) paper (Review of Financial Studies 10, 1035-1064.
Can you please tell me what I am doing wrong? Standard errors and t statistics for Rv coefficient is not produced. I need to estimate the model with GMM. MRR argues that it would be better to estimate with GMM. I can post these papers if you want me to. Thank you, Onem
Here is my program and results:
*A=1 if transaction is buyer initiated and A=-1 if trade is seller initiated.
*L1A is last A.
*TrPrice is transaction price and L1TrPrice is last transaction price.
set Ret = 100*log(TrPrice/L1TrPrice)
set Ret = 1000*Ret
nonlin KV TV RV
frml MRR Ret = (KV+TV)*A-(KV+RV*TV)*L1A
linreg Ret
# A L1A
compute KV=%beta(1)*0.5
compute TV=%beta(1)*0.5
compute RV=0.5
instruments constant Ret{2 to 5} A{2 to 5}
nlls(PMETHOD=simplex,PITERS=10,METHOD=GAUSS,inst,optimal,trace,frml=MRR) Ret
Linear Regression - Estimation by Least Squares
Dependent Variable RET
Usable Observations 1778679
Degrees of Freedom 1778677
Centered R^2 0.1720066
R-Bar^2 0.1720061
Uncentered R^2 0.1720085
Mean of Dependent Variable 0.0055888717
Std Error of Dependent Variable 3.7038836737
Standard Error of Estimate 3.3703181945
Sum of Squared Residuals 20204071.608
Log Likelihood -4684942.8910
Durbin-Watson Statistic 2.1939
1. A 1.510307256 0.002566376 588.49795 0.00000000
2. L1A -0.647940378 0.002566376 -252.47285 0.00000000
Simplex Optimization, Trial 0. Function Calls: 4
Old Function = 3935.609187 New Function = 3772.618781
New Coefficients:
0.755154 0.679638 0.500000
Simplex Optimization, Trial 1. Function Calls: 6
Old Function = 3772.618781 New Function = 3593.108769
New Coefficients:
0.679638 0.679638 0.600000
Simplex Optimization, Trial 58. Function Calls: 115
Old Function = 2456.168287 New Function = 2446.621522
New Coefficients:
0.672546 -0.663959 0.600750
Simplex Optimization, Trial 60. Function Calls: 118
Old Function = 2446.621522 New Function = 2444.200720
New Coefficients:
0.641206 -0.712687 0.596366
Simplex Optimization, Trial 62. Function Calls: 122
Old Function = 2444.200720 New Function = 2442.996142
New Coefficients:
0.652400 -0.695724 0.588318
Non-Linear Optimization, Iteration 0. Function Calls 125.
Cosine of Angle between Direction and Gradient 0.2649041. Alpha used was 0.000000
Adjusted squared norm of gradient 1.9375
Diagnostic measure (0=perfect) 0.0000
Subiterations 1. Distance scale 1.000000000
Old Function = 2442.996142 New Function = 2441.259445
New Coefficients:
0.642880 -0.727518 0.588318
Non-Linear Optimization, Iteration 1. Function Calls 127.
Cosine of Angle between Direction and Gradient 0.5671303. Alpha used was 0.000000
Adjusted squared norm of gradient 1.907987
Diagnostic measure (0=perfect) 0.7000
Old Function = 44.845186 New Function = 42.987933
New Coefficients:
0.655094 -0.523148 0.588318
Non-Linear Optimization, Iteration 2. Function Calls 129.
Cosine of Angle between Direction and Gradient 0.2359073. Alpha used was 0.000000
Adjusted squared norm of gradient 0.0001497426
Diagnostic measure (0=perfect) 0.4200
Old Function = 44.087863 New Function = 44.087707
New Coefficients:
0.654841 -0.521565 0.588318
Non-Linear Optimization, Iteration 3. Function Calls 131.
Cosine of Angle between Direction and Gradient 0.2336698. Alpha used was 0.000000
Adjusted squared norm of gradient 5.243121e-009
Diagnostic measure (0=perfect) 0.2520
Old Function = 44.094143 New Function = 44.094143
New Coefficients:
0.654839 -0.521556 0.588318
GMM-Continuously Updated Weight Matrix - Estimation by Gauss-Newton
Convergence in 3 Iterations. Final criterion was 0.0000091 <= 0.0000100
Usable Observations 1778674
Degrees of Freedom 1778671
Mean of Dependent Variable 0.0055756956
Std Error of Dependent Variable 3.7038749710
Standard Error of Estimate 3.6333416051
Sum of Squared Residuals 23480540.413
J-Specification(7) 44.0941
Significance Level of J 0.0000002
Durbin-Watson Statistic 2.1814
1. KV 0.654839007 0.033694981 19.43432 0.00000000
2. TV -0.521556067 0.153608657 -3.39536 0.00068539
3. RV 0.588317639 0.000000000 0.00000 0.00000000
