Question about X11
Posted: Tue May 02, 2017 12:09 pm
just want to make sure I am interpreting the tests within the x11 procedure correctly. It is my understanding that the null hypothesis in the stable and moving seasonality tests is "no season effects" are present. So if we have data with season effects, we should be rejecting the null, such as:
Is this the correct interpretation? And, second question, is there a defined variable that retains the test statistics/significance levels? From the documentation I think the answer is "no."
Thank you
Stable Seasonality Test
Sum of Degrees of Mean
Squares Freedom Square
Between Periods 0.000079 3 0.000026
Residual 0.000374 129 0.000003
Total 0.000453 132
F-Ratio 9.07832 Significance Level (P) 0.0000170
Nonparametric Test for the Presence of Seasonality Assuming Stability
KW Statistic 21.585016 DOF 3 P-level 0.000080
Moving Seasonality Test
Between Years 0.000060 32 0.000002
Error 0.000115 96 0.000001
F-Ratio 1.55987 Significance Level (P) 0.0510248D9. Final replacement values for SI ratiosThank you
