ARMA-GARCH Model
Posted: Fri Jun 23, 2017 4:33 am
Dear all
I have some problem with my code to forecasting based on ARMA-GARCH model and AR(1). Indeed, have 2 points:
1. My data are ranged from 2000:1:1 to 2017:1. I want to do forecasting only during the period 2000:1:1 to 2013:12 and then do forecast during the period 2014:1 to 2017:1. Therefore I have specified the following line in my code SMPL 1985:1 2013:12. When I do this the forecasting based on GARCH did not work and I have the following message:
## REG20. GARCH Cannot Be Used with Gaps/Missing Values
2. My second concern is about how we get the forecasted values of my variance based on GARCH in order to do the test of Diebold and Mariono.
My code is as follows
CALENDAR(M) 2000:1:1
Allocate 2015:12
OPEN DATA
data(format=xls,org=columns)
print
SMPL 2000:1:1 2013:12
equation(AR=6, MA=5) M1eq infa
group garch1 M1eq
garch(model=garch1, p=1,q=1,ASYMMETRIC, hseries=h,resids=u) / infa
@garchfore(steps=13) h u
forecast(model=garch1,from=2000:1,to=2017:1,results=rhat)
print / h
thank you a lot
Allocate 2015:12
OPEN DATA
group garch1 M1eq
print / h
thank you a lot
