Orthogonal Shocks Sign Restrictions
Posted: Wed Aug 09, 2017 5:54 am
I am working on the Mountfort Uhlig (2009) code which is doing the sign restrictions on multiple shocks where the first two are constructed to be orthogonal:
The question is reagrding the use of the @forcedfactor procedure.
It takes the Cholesky decomposition of the covariance matrix, sigmad, and factorizes it such that "i1" is the first column and the resulting matrix "f" fulfills ff'=sigmad.
What I dont get is what
does.
In the VAR workbook something like "we
need to back transform draws, thus the complete process.." is written, but I dont understand what that means.
Best Jules
* Replication file for Mountford and Uhlig (2009), "What are the Effects
* of Fiscal Policy Shocks?", Journal of Applied Econometrics.
* Experiment with sign restrictions rather than penalty functions
* nkeep is the desired number of accepted draws
compute nkeep=250
compute n1 =500
compute n2 =1000
* Pull in common setup
source mujaesetup.src
* Range of steps to constrain. Note - these are based at 1, not 0.
compute KMIN =1
compute KMAX =4
* Parameter vectors for the nested optimization problems. They should
* have a size equal to nvar less 1 + the number of constraints imposed
* prior to their estimation. Those prior constraints can be
* orthogonality to previous shocks, or can be zero restrictions.
compute nshocks=4
dec vect[strings] sl(nshocks)
compute sl=||"Business Cycle","Monetary Policy","Revenue","Spending"||
compute ones=%const(1.0)
source forcedfactor.src
infobox(action=define,progress,lower=1,upper=n1) "Monte Carlo Integration"
compute accept=0
do draw=1,n1
* responses.
compute sigmad =%ranwisharti(svt,wishdof)
compute p =%decomp(sigmad)
compute betadraw=betaols+%ranmvkron(p,sxx)
impulse(noprint,model=varmodel,factor=p,results=impulses,steps=nstep)
gset irfsquared 1 1 = %xt(impulses,t).^2
do subdraw=1,n2
* First in Order - Business Cycle Vector
compute [vector] v1=%ransphere(nvar)
if UhligAccept(v1,KMIN,KMAX,||+1,+3,+8,+9||)==0
goto reject
compute i1=p*v1
* Compute a factor with i1 forced as the first column.
* Transform the orthogonal complement (remaining columns) back into weights on
* the Choleski factor.
compute r2=inv(p)*%xsubmat(f,1,nvar,2,nvar)
* Second in Order - Monetary Shock
compute [vector] v2=r2*%ransphere(nvar-1)
if UhligAccept(v2,KMIN,KMAX,||+4,-5,-6,-7||)==0
goto reject
compute i2=p*v2
* Compute a factor with i1~i2 forced as the first two columns.
@forcedfactor(force=column) sigmad i1~i2 f
compute r3=inv(p)*%xsubmat(f,1,nvar,3,nvar)
* Third in Order - Govt Revenue Shock (no delay)
* Draw from the orthogonal complement of i1 and i2 (final nvar-2 columns
* in the factor).
compute [vector] v3c=r3*%ransphere(nvar-2)
if UhligAccept(v3c,KMIN,KMAX,||+3||)==0
goto reject
compute i3c=p*v3c
* Third in Order - Govt Spending Shock (no delay)
compute [vector] v3e=r3*%ransphere(nvar-2)
if UhligAccept(v3e,KMIN,KMAX,||+2||)==0
goto reject
compute i3e=p*v3e
* Meets all restrictions
compute accept=accept+1
dim %%responses(accept)(nshocks*nvar,nstep)
* Save the desired sets of linear combinations of the Choleski
* responses
compute vweights=v1~v2~v3c~v3e
ewise %%responses(accept)(i,j)=(ik=%vec(%xt(impulses,j)*vweights)),ik(i)
if accept>=nkeep
break
:reject
end do subdraw
if accept>=nkeep
break
infobox(current=draw)
:newdraw
end do draw
infobox(action=remove)
disp "Acceptances" accept "on" draw "main draws"
@MCGraphIRF(model=varmodel,varlabels=vl,shocklabels=sl,$
page=byshock,center=median,columns=2,include=||1,2,10,4,6,8,3,9,5,7||)
* Combination shocks
* Spending = variable 2, revenue = variable 3
* Revenue = shock 3, Spending = shock 4
compute [vect[integer]] xvars=||2,3||
compute [vect[integer]] xshocks=||3,4||
dec rect xsolve(2,2)
dec rect xrespy(nvar,2)
dec vect yresp(nvar)
* Target values for spending,revenue for the combination shocks
dec vect[vect] experiments(3)
compute experiments(1)=||1.0,0.0||
compute experiments(2)=||0.0,-1.0||
compute experiments(3)=||1.0,1.0||
compute [vect[strings]] cl=||"Deficit Spending","Deficit Tax Cut","Balanced Budget"||
dec vect[vect] target(KMAX)
dec vect[rect] %%combos
dim %%combos(nkeep)
do draw=1,nkeep
compute %%combos(draw)=%zeros(%rows(experiments)*nvar,nstep)
do k=1,%rows(experiments)
* Copy the target values for each step being constrained.
do s=1,KMAX
compute target(s)=experiments(k)
end do s
do s=1,KMAX
* Compute the shock needed at step <<s>> to hit the remainder.
* This is always computed using the impact multipliers.
compute xresp=%reshape(%xcol(%%responses(draw),1),nvar,nshocks)
ewise xsolve(i,j)=xresp(xvars(i),xshocks(j))
compute needed=%solve(xsolve,target(s))
* Propagate that shock through to the responses being
* constructed. Since this is a shock at step <<s>>, the
* response to it at step <<u>> is computed using the IRF at
* u-s+1.
do u=s,nstep
compute xresp=%reshape(%xcol(%%responses(draw),u-s+1),nvar,nshocks)
* Pull out the responses of all variables to the two shocks
* being combined. Take the linear combination of these that
* we just computed. Add it to the running sums.
ewise xrespy(i,j)=xresp(i,xshocks(j))
compute yresp=xrespy*needed
do i=1,nvar
compute %%combos(draw)(i+(k-1)*nvar,u)+=yresp(i)
* If u is inside of the number of steps being constrained,
* update the target by subtracting off the response to the
* shock we just computed.
if u<=KMAX {
compute target(u)=target(u)-xsolve*needed
end do u
end do s
end do k
end do draw
* Copy the information generated into %%responses so we can use MCGraphIRF
compute %%responses=%%combos
@MCGraphIRF(model=varmodel,varlabels=vl,shocklabels=cl,$
"@forcedfactor(force=column) sigmad i1 f"What I dont get is what
compute r2=inv(p)*%xsubmat(f,1,nvar,2,nvar)does.
Best Jules
