Sign Restriction with 30 observations?
Posted: Thu Sep 21, 2017 3:59 pm
by umee
Is VAR analysis with 30 data points possible. Specifically, sign-restriction analysis with 7 variables, 6 of which are restricted?
Re: Sign Restriction with 30 observations?
Posted: Thu Sep 21, 2017 4:56 pm
With a one-lag VAR, you could do it. Two lags would come pretty close to running you out of degrees of freedom for the covariance matrix.
Posted: Fri Nov 24, 2017 5:41 pm
by umee
Tom,
To get more observations I switched from quarterly to monthly data. However, running the sign-restricted VAR with monthly data leads to very large percent changes; instead of a .04 change, now I see changes of 20 or 30. Any idea what could be driving this? Is it just of function of rescaling my data? I wouldn't think that should be an issue.
FYI - I'm using the code from Uhling 2005 to look at the effect of monetary policy on employment.
Posted: Sat Nov 25, 2017 3:43 am
How did you "rescale the data"? Yes, changing the scale of the data changes the scale of the responses.
Posted: Sat Nov 25, 2017 2:28 pm
by umee
Thanks. The scaling of the GDP deflator varied substantially.
Posted: Sat Nov 25, 2017 6:06 pm
I'm confused. The scaling of a variable should be up to you. How does it "vary considerably"?
Posted: Sun Nov 26, 2017 3:30 pm
by umee
With the quarterly data I used data on GDP and the GDP deflator from FRED, but with the monthly data I found a monthly GDP measure and I computed the GDP delfator as (Nominal/Real)*100. For the monthly data I had values like 5 and 6, but for the quarterly data the measures were 100, 102, etc. So I scrapped the GDP measure that I computed and just used monthly CPI data from FRED.
Posted: Sun Nov 26, 2017 4:34 pm
If you're going to convert those to logs anyway (you are, aren't you??), it doesn't matter---the scale of a price index is arbitrary.
Posted: Mon Nov 27, 2017 12:56 pm
by umee
Yes, I did convert them to logs.
