The Mean Model of Triangular BEKK
Posted: Fri Dec 08, 2017 6:53 pm
I have estimated a triangular BEKK model and applied restrictions to the mean model following the RATS user's guide. In the output results, I obtained standard results for the variance equation but all coefficients, standard errors, and t-statistics in the mean model are zeros (except the constants). I don't understand why all of these values should be zeros given that in the unrestricted version (full BEKK model), I obtained non-zero coefficients and standard errors. I have provided the output results from RATS below, and will be glad if you could look at the results and advice me on what I am not doing right.
Thank you.
Thank you.
dec symm[series] hhs(4,4)
clear(zeros) hhs
equation dlgsecieq dlgseci
#constant hhs(1,1)
equation dlexreq dlexr
#constant hhs(2,1) hhs(2,2)
equation dlsp500eq dlsp500
#constant hhs(3,1) hhs(3,2) hhs(3,3)
equation dlcopeq dlcop
#constant hhs(4,1) hhs(4,2) hhs(4,3) hhs(4,4)
group garchm dlgsecieq dlexreq dlsp500eq dlcopeq
GARCH(MODEL=GARCHM,P=1,Q=1,MV=TBEKK,ASYMMETRIC,ITERS=300,PMETHOD=BFGS,PITERS=15,hmatrices=hh,rvectors=rd) / DLGSECI DLEXR DLSP500 DLCOP
MV-GARCH, Triangular BEKK - Estimation by BFGS
Convergence in 185 Iterations. Final criterion was 0.0000019 <= 0.0000100
Monthly Data From 1991:02 To 2015:12
Usable Observations 299
Log Likelihood 2127.3012
1. Constant 0.007287757 0.002922266 2.49387 0.01263581
2. HHS(1,1) 0.000000000 0.000000000 0.00000 0.00000000
3. Constant 0.000826671 0.000387885 2.13123 0.03307024
4. HHS(2,1) 0.000000000 0.000000000 0.00000 0.00000000
5. HHS(2,2) 0.000000000 0.000000000 0.00000 0.00000000
6. Constant 0.007470998 0.002435940 3.06699 0.00216228
7. HHS(3,1) 0.000000000 0.000000000 0.00000 0.00000000
8. HHS(3,2) 0.000000000 0.000000000 0.00000 0.00000000
9. HHS(3,3) 0.000000000 0.000000000 0.00000 0.00000000
10. Constant 0.005727075 0.004805212 1.19185 0.23332146
11. HHS(4,1) 0.000000000 0.000000000 0.00000 0.00000000
12. HHS(4,2) 0.000000000 0.000000000 0.00000 0.00000000
13. HHS(4,3) 0.000000000 0.000000000 0.00000 0.00000000
14. HHS(4,4) 0.000000000 0.000000000 0.00000 0.00000000
15. C(1,1) 0.034613887 0.002305262 15.01517 0.00000000
16. C(2,1) 0.000874804 0.000468841 1.86589 0.06205718
17. C(2,2) 0.000456205 0.000527188 0.86536 0.38684328
18. C(3,1) 0.000901935 0.002253929 0.40016 0.68903778
19. C(3,2) -0.012983218 0.004191467 -3.09754 0.00195137
20. C(3,3) 0.003382128 0.011754729 0.28772 0.77355736
21. C(4,1) -0.005618728 0.005869985 -0.95720 0.33846813
22. C(4,2) 0.015542818 0.056620967 0.27451 0.78369548
23. C(4,3) 0.066699124 0.013939963 4.78474 0.00000171
24. C(4,4) 0.000025343 0.736505280 3.44099e-005 0.99997254
25. A(1,1) 1.016137853 0.084164661 12.07321 0.00000000
26. A(2,1) 0.010817680 0.007489986 1.44429 0.14865862
27. A(2,2) 0.978339477 0.076422234 12.80177 0.00000000
28. A(3,1) -0.048196786 0.039851345 -1.20941 0.22650373
29. A(3,2) 0.083924082 0.112085577 0.74875 0.45400787
30. A(3,3) 0.017158161 0.081237668 0.21121 0.83272385
31. A(4,1) 0.051823080 0.094125855 0.55057 0.58192696
32. A(4,2) 0.151954774 0.280599206 0.54154 0.58813770
33. A(4,3) -0.028549195 0.350842007 -0.08137 0.93514503
34. A(4,4) 0.117005112 0.092013090 1.27161 0.20351038
35. B(1,1) 0.271326783 0.047252317 5.74208 0.00000001
36. B(2,1) -0.033803882 0.005915303 -5.71465 0.00000001
37. B(2,2) 0.744532071 0.025640440 29.03741 0.00000000
38. B(3,1) 0.015439658 0.038029000 0.40600 0.68474484
39. B(3,2) -0.037870259 0.049079703 -0.77161 0.44034702
40. B(3,3) 0.836755182 0.053515031 15.63589 0.00000000
41. B(4,1) 0.067987728 0.091446223 0.74347 0.45719582
42. B(4,2) -0.146075380 0.196044092 -0.74511 0.45620225
43. B(4,3) -0.200949576 0.372875362 -0.53892 0.58994282
44. B(4,4) -0.038945271 0.228487879 -0.17045 0.86465793
45. D(1,1) 0.220802608 0.248872367 0.88721 0.37496465
46. D(2,1) 0.003665049 0.015640566 0.23433 0.81472901
47. D(2,2) 0.160011503 0.239120904 0.66917 0.50338979
48. D(3,1) 0.144159672 0.059414949 2.42632 0.01525282
49. D(3,2) -0.176506194 0.227106980 -0.77719 0.43704429
50. D(3,3) 0.530086765 0.086254712 6.14560 0.00000000
51. D(4,1) -0.740725784 0.243103775 -3.04695 0.00231174
52. D(4,2) -4.249638024 1.430087281 -2.97159 0.00296259
53. D(4,3) 0.475161631 0.227899202 2.08496 0.03707257
54. D(4,4) 0.499860582 0.100747177 4.96153 0.00000070
