GJR GARCH with dummy variable in variance equation
Posted: Thu Dec 28, 2017 9:30 am
by emna
I use the following code to estimate a GJR-GARCH(1,1) model with dummy variable in variance eqation
r(t)=beta(1)+beta(2)*r(t-1)
sigma(t)^2=alpha0 + alpha1*u{1}^2+ %if(u{1}<0.0,gamma1*u{1}^2,0.0)+ %if(u{1}<0.0,gamma2*dummy*u{1}^2,0.0)+gammadummy*dummy + beta1*h{1}
clear all
open data PUT ARCH GARCH.xls
data(format=xls,org=columns)
set x = rendement
linreg x
# constant x{1}
frml(lastreg,vector=beta) meanf
nonlin(parmset=meanparms) beta
set uu = %seesq
set h  = %seesq
set u  = 0.0
nonlin(parmset=garchparms) alpha0 alpha1 beta1 gamma1 gamma2 gammadummy
compute alpha1=gamma1=gamma2=0.005, beta1=0.004,alpha0=%seesq*(1-alpha1-beta1), gammadummy=0.1
   frml varf = alpha0 + beta1*h{1} + alpha1*u{1}^2+ %if(u{1}<0.0,gamma1*u{1}^2,0.0)+ %if(u{1}<0.0,gamma2*dummy*u{1}^2,0.0)+gammadummy*dummy
   frml logl = (h(t)=varf(t)),(u=x-meanf),$
       (uu(t)=u^2),%logdensity(h,u)
maximize(parmset=meanparms+garchparms,pmethod=simplex,piters=100,robust, iters=2500) logl 3 *
My problem is that model don't converge so I have this message
"NO CONVERGENCE IN 7 ITERATIONS. FINAL NORMED GRADIENT 1.43753
SUBITERATIONS LIMIT EXCEEDED.
TRY DIFFERENT SETTING FOR EXACTLINE, DERIVES OR ALPHA ON NLPAR
RESTARTING ESTIMATION FROM LAST ESTIMATES OR DIFFERENT INITIAL GUESSES/PMETHOD OPTION MIGHT ALSO WORK
With Heteroscedasticity/Misspecification Adjusted Standard Errors"
I don't know if there is any problem with the code or initial values perhaps or another one... Have you any explanations or comments about my model please ?
Best regards,
Emna
Re: GJR GARCH with dummy variable in variance equation
Posted: Thu Dec 28, 2017 10:27 am
In terms of the model, is there a reason that you don't have a dummy x a standard lagged squared residual, just the asymmetric term and the variance constant?
First, that's way too many simplex iterations. Have you actually tried a regular GJR model? You're using guess values which have effectively no GARCH properties. Starting with guess values off a standard GJR with zeros for the dummy coefficients would be the obvious way to start that.
Posted: Thu Dec 28, 2017 1:47 pm
by emna
Thank you for your response.
1/ In terms of the model I guess that there is a structural break in terms of asymmetry and variance level after a regulation reform that's why I introduce dummy variable for these to variables.
2/ My results for the regular GJR model are as the following :
garch(p=1,q=1,asymmetric) / x
Convergence in    47 Iterations. Final criterion was  0.0000031 <=  0.0000100
Dependent Variable X
Usable Observations                       742
Log Likelihood                     -3366.0123
1.  Mean(X)                       -8.27906643   0.43129314    -19.19591  0.00000000
2.  C                             73.88707348   6.42176267     11.50573  0.00000000
3.  A                             -0.00750951   0.00060380    -12.43708  0.00000000
4.  B                              0.24756667   0.02306927     10.73145  0.00000000
5.  D                              7.71784140   1.01378913      7.61287  0.00000000
or if I use my code :
clear all
set x = rendement
linreg x
# constant x{1}
Usable Observations                       741
Degrees of Freedom                        739
Centered R^2                        0.0163383
R-Bar^2                             0.0150072
Uncentered R^2                      0.0163383
Mean of Dependent Variable        -0.00030205
Std Error of Dependent Variable   55.39263374
Standard Error of Estimate        54.97541708
Sum of Squared Residuals         2233477.1012
Regression F(1,739)                   12.2746
Significance Level of F             0.0004868
Log Likelihood                     -4019.5347
Durbin-Watson Statistic                2.0372
1.  Constant                     -0.000158954  2.019572410 -7.87066e-05  0.99993722
2.  X{1}                         -0.127822302  0.036484100     -3.50351  0.00048681
set uu = %seesq
set h  = %seesq
set u  = 0.0
compute alpha1=5.35, beta1=0.15, alpha0=17.82, gamma1=7
maximize(parmset=meanparms+garchparms, pmethod=simplex,piters=100,robust, iters=2500) logl 3 *
MAXIMIZE - Estimation by BFGS
Convergence in     1 Iterations. Final criterion was  0.0000032 <=  0.0000100
LOW ITERATION COUNT ON BFGS MAY LEAD TO POOR ESTIMATES FOR STANDARD ERRORS
Function Value                     -3353.9447
1.  BETA(1)                       -8.34554976   0.23799029    -35.06677  0.00000000
2.  BETA(2)                       -0.05954196   0.00974185     -6.11197  0.00000000
3.  ALPHA0                        72.62874708   2.95069357     24.61413  0.00000000
4.  ALPHA1                        -0.00736835   0.00241010     -3.05727  0.00223360
5.  BETA1                          0.24649718   0.00673153     36.61831  0.00000000
6.  GAMMA1                         7.25913378   0.25105248     28.91481  0.00000000
Posted: Thu Dec 28, 2017 2:03 pm
by emna
And now my model with regular GJR initial values converges but with Heteroscedasticity/Misspecification Adjusted Standard Errors
set x = rendement
linreg x
# constant x{1}
R-Bar^2                             0.0150072
set uu = %seesq
set h  = %seesq
set u  = 0.0
compute alpha1=-0.00750951, gamma1=gamma2=7.71784140, beta1=0.24756667,alpha0=73.88707348, gammadummy=0.1
Convergence in     1 Iterations. Final criterion was  0.0000000 <=  0.0000100
Function Value                     -3348.7826
1.  BETA(1)                       -8.44174085   0.24596736    -34.32057  0.00000000
2.  BETA(2)                       -0.05829411   0.01013334     -5.75270  0.00000001
3.  ALPHA0                        90.58382604   3.52665946     25.68545  0.00000000
4.  ALPHA1                        -0.00775954   0.00231308     -3.35464  0.00079469
5.  BETA1                          0.25307723   0.00688866     36.73826  0.00000000
6.  GAMMA1                         6.29770606   0.25199883     24.99101  0.00000000
7.  GAMMA2                         1.62059489   0.34877321      4.64656  0.00000338
8.  GAMMADUMMY                   -36.43453397   5.06935847     -7.18721  0.00000000
maximize(parmset=meanparms+garchparms, method= BHHH, pmethod=simplex,piters=100,robust, iters=2500) logl 3 *
MAXIMIZE - Estimation by BHHH
Convergence in     6 Iterations. Final criterion was  0.0000081 <=  0.0000100
1.  BETA(1)                       -8.44178069   0.44405083    -19.01084  0.00000000
2.  BETA(2)                       -0.05829719   0.02085195     -2.79577  0.00517767
3.  ALPHA0                        90.58637091   5.97952022     15.14944  0.00000000
4.  ALPHA1                        -0.00775944   0.00332409     -2.33431  0.01957973
5.  BETA1                          0.25307885   0.01912558     13.23248  0.00000000
6.  GAMMA1                         6.29763060   0.76974334      8.18147  0.00000000
7.  GAMMA2                         1.62070821   0.58521005      2.76945  0.00561515
8.  GAMMADUMMY                   -36.43666756   7.60316141     -4.79230  0.00000165
What do you think about this please ?
Posted: Thu Dec 28, 2017 5:26 pm
Until you fix the fact that you didn't put your chosen mean model into the GARCH instruction (you didn't include the lagged dependent variable---you need to use the REGRESSORS option to put in a non-trivial mean model), I can't be sure, but that looks like you have a major problem with your data. The asymmetry coefficient should not be that big---it really shouldn't be bigger than 1, and usually is more like .1 or .2 at the outside.
Posted: Thu Dec 28, 2017 5:45 pm
by emna
please find the dataset used to estimate the model in the an attachment
Posted: Thu Dec 28, 2017 7:01 pm
OK. Have you looked at that series? What's with those monster spikes, and what do you plan to do about it?
Posted: Thu Jan 11, 2018 9:53 am
by emna
I have an database of option prices. As you know, for each trading day the option prices differ according to the exercise price and the number of days remaining until maturity. In order to keep a single price, I have use only ATM options that have the shortest term since they represent the most liquid contracts. The problem here is that the data has peaks each time we have a big difference between the maturities (see example attached
mydata.xls
example
(63 KiB) Downloaded 1004 times
So I do not know if you have an idea how I should choose the options to avoid this problem
Posted: Thu Jan 11, 2018 1:10 pm
That sounds like something that you really need to be discussing with your research advisor. A GARCH model assumes that the DGP for the variance is the same from period to period. It's not clear that anything like that is true for options at a daily level even when the contract isn't changing from day to day, and clearly isn't at all true when the contract shifts.
