Dynamic panels with threshold effect and endogeneity
Posted: Tue Nov 06, 2018 9:09 am
Good day,
Wonder if anyone has please developed a RATS code for the paper "Dynamic panels with threshold effect and endogeneity" by Seo and Shin (2016). Journal of Econometrics
Volume 195, Issue 2, December 2016, Pages 169-186.
This is the gauss code and attached the data.
oz
oz
/* Gauss code to implement
1. 2-step FD-GMM for dynamic threshold panel
i. Can allow for threshold effect in the intercept as well
ii. averaging involves some randomness in the estimates
iii. choice of IV can alter the estimates. See procedure setiv
2. Testing for Linearity
Refer to â€Dynamic Panel with Endogeneity and threshold effect",
written by Myung H Seo.
reference: Hansen 1999 (I copied some part of his code here)
"Threshold effects in non-dynamic panels: Estimation, testing and inference"
Journal of Econometrics (1999)
Minjoo Kim has also contributed. */
new; format /rd /m1 8,4; output file= invest.out on;
tstart = date;
load invest; // Load data and define variables
t = 15;
nt = rows(invest);
n = nt/t;
y = invest[.,1]; @ investment/assets @
Tq = invest[.,2]; @ Tobin's Q @
c = invest[.,3]; @ cash-flow/assets @
d = invest[.,4]; @ debt/assets @
/***************************** Controls *******************************/
qn = 200; @ number of quantiles to examine @
_trim_1 = .15; @ percentage to trim before search, single @
_con = 0; if _con ==0; "no constant"; elseif _con==1;
"constant in the upper regime";endif;
ns = 200; @ iter num in averaging (1st uses analytic formula) @
nb = 0; @ bootstrap iteration @
jmy = 1; @ number of lags of y used in IV ( jm >= 1) @
jmx = 1; @ number of lags of x used in IV ( jm >= 1) @
jn = 1; @ initial lag used in IV is t-jn-2 (jn >=0) @
t0 = jn+3; @ initial time in GMM ( >= jn+3) @
jj=1000; @ iteration for linearity test p-value @
x = c~Tq~d; @ set regressors @
// tt= ones(n,1).*.eye(t); tt= tt[.,t0+1:t]; // time dummies. SET _con =0
// x = x~tt; with dummies we need more IV's as they are already part of IVs
q = c;
xx= ones(nt,1)~tq; @ variables to be used as IV: FIRST COLUMN MUST BE 1's@
"threshold variable = c ";
"qn~ns~jm~jn~t0 : " qn~ns~jmy~jn~t0;
w = setiv(n,t,y,xx,t0,jmy,jmx,jn);" number of moments: " cols(w);
dd = unique(q,1);
qnt1 = qn*_trim_1;
sq = seqa(_trim_1,1/qn,qn-2*qnt1+1);
qq1 = dd[floor(sq*rows(dd))]; @ grid for threshold values @
qn1 = rows(qq1);
ly = vec(lagn(reshape(y,n,t)',1)); // ntx1
dy = y-ly; // ntx1
z2 = ly;
k=cols(x); z2 = ly~x;
z1 = z2;
if _con == 1; z1= (z2~ones(n*t,1)); endif;
k1 = cols(z1); k2 = cols(z2);
dz0 = {} ; @ stack of dz's across threshold values @
for i (1,qn1,1);
z = z2~(z1.*(q.> qq1[i])); // ntx[(1+k)+(1+k)+1]
lz = lagnmatrix(n,t,z,1); // ntx[(1+k)+(1+k)]
dz = z-lz; // ntx[(1+k)+(1+k)]
tmp = packr(dy~dz); // n(t-2)x[1+(1+k)+(1+k)]
tmp = trimrmatrix(n,t-2,tmp,t0-3,0);
dz = tmp[.,2:cols(tmp)]; // n(t-t0+1)x(1+k+1+1+k)
dz0=dz0|dz;
endfor; dy = tmp[.,1];
// ************************** 1st step GMM
zst = rndn(cols(w),jj); // random numbers for linearity test
thtsample = {}; Jsample={};
wnst_A = zeros(qn1,jj); wn_A = zeros(qn1,1);
colp = zeros(ns,1);
for iter (1,ns,1);
if iter == 1; iv = weight1(n,t,w,t0); else;
e = rndn(t-1,n); // (t-1)xn, simulating homogeneous case
de = vec(e[2:t-1,.]-e[1:t-2,.]); // n(t-2)x1
iv = weight(n,t,de,w,t0);
endif;
col1={};
for i (1,qn1,1);
dz = dz0[(i-1)*n*(t-t0+1)+1:i*n*(t-t0+1),.];
wdz = (w'dz)/n; // mx(1+k+1+1+k)
wdy = (w'dy)/n; // mx1
trap 1; iwdz = inv(wdz'*iv*wdz); trap 0;
if scalerr(iwdz); iwdz = invswp(wdz'*iv*wdz);
" error in the 1st step " i; endif;
b = iwdz*(wdz'*iv*wdy); // (1+k+1+k)x1
wde = wdy-wdz*b; // mx1
s = wde'*iv*wde; // scalar
dehat = dy-dz*b; // n(t-2)x1
col1=col1|(s~qq1[i]~b'~dehat');
endfor;
col1hat=sortc(col1,1);
dehat = col1hat[1,2+rows(b)+1:cols(col1)]';
// ************************** 2nd step GMM
iv = weight(n,t,dehat,w,t0);
wnst=zeros(qn1,jj);
wn = zeros(qn1,1);
col2={};
for i (1,qn1,1);
" error in the 2nd step " i; endif;
col2=col2|(s~qq1[i]~b'~dehat');
//-- supW statistic
p1 = zeros(k1,k2)~eye(k1);
ivi = weight(n,t,col1[i,2+rows(b)+1:cols(col1)]',w,t0);
iv2 = chol(ivi);
trap 1; iwdzi = inv(wdz'*ivi*wdz); trap 0;
if scalerr(iwdzi); iwdzi = invswp(wdz'*ivi*wdz);
idti = inv(p1*iwdzi*p1');
wn[i] = n*(p1*b)'idti*(p1*b);
for j (1,jj,1);
wnst[i,j] = zst[.,j]'iv2*wdz*iwdzi*p1'idti*p1*iwdzi*wdz'iv2'zst[.,j];
endfor;
endfor;
col2hat=sortc(col2,1);
dehat = col2hat[1,2+rows(b)+1:cols(col2hat)]';
thtsample = thtsample|col2hat[1,2:2+rows(b)];
Jsample = Jsample|(n*col2hat[1,1]);
colp[iter] = 1-counts(maxc(wnst),maxc(wn))/jj; //linearity test
wnst_A = wnst_A + wnst; wn_A = wn_A + wn;
endfor;
ththat = meanc(thtsample); // averaged estimate, (1+k+1+k)x1
ththat1= thtsample[1,.]'; // estimate from analytic Weight
Jhat = meanc(Jsample); // averaged J statistic
Jhat1= Jsample[1]; // J stat from analytic Weight
ltp_A = 1-counts(maxc(wnst_A),maxc(wn_A))/jj;
"";" linearity test from analytic : " colp[1];
" linearity test from averaging: " ltp_A; "";
""; "/------ output based on analytic variance formula -----/";"";;
{dum1,dum2,dum3,dum4}=printout(n,t,t0,w,dy,q,ththat1,z1,z2,Jhat1,_con);
//dum1: s.e.; dum2: upper regime estimates and s.e.;
//dum3: long-run parameter estimates and s.e. dum4: Jstat and p-value
if ns > 1; ""; "/------ in case of averaging -----/";"";;
{dum1,dum2,dum3,dum4}=printout(n,t,t0,w,dy,q,ththat,z1,z2,Jhat,_con);
endif;
tend = date;et = etstr(ethsec(tstart,tend)); "";" elapsed time : " et;
end;
input :
t0: initial time for the moment condition
jm's: maximum lags to be used as an IV
x: should contain ones in the first column
proc setiv(n,t,y,x,t0,jmy,jmx,jn);
local er,er1,j,k,m,i,zyi,zxi,wi,sr,w,sj,mj;
k = cols(x); // x[.,1]=1
w = {};
for i (1,n,1);
zyi = y[(i-1)*(t)+1:i*(t)]; // (t)x1
zxi = x[(i-1)*(t)+1:i*(t),.]; // (t)xk
wi = {}; // (t-t0+1)xm
er = 0; er1=0; // scalar
for j (1,t-t0+1,1);
sj = j+t0-jn-3;
mj = 1+ minc(jmy|sj);
wi = wi~zeros(t-t0+1,mj);
sr = er+1; // scalar
er1 = er+ mj; // scalar
er = er1;
wi[j,sr:er1]=1~zyi[maxc(1|sj-jmy+1):sj]';
if k > 1;
mj = (-1+k)*minc(jmx|sj);
er = er1+ mj; // scalar
wi[j,er1+1:er]= vec(zxi[maxc(1|sj-jmx+1):sj,2:k])';
endif;
endfor;
w = w|wi; // (t-t0+1)xm
endfor;
retp(w); endp;
/* input:
de: residuals
w : IV's
proc weight(n,t,de,w,t0); // with given residuals
local v,vbar,i,dei,wi,iv;
v = 0; // scalar
vbar = 0;
for i (1,n,1);
dei = de[(i-1)*(t-t0+1)+1:i*(t-t0+1),.]; // (t-2)x1
wi = w[(i-1)*(t-t0+1)+1:i*(t-t0+1),.]'dei; // m x 1
v = v + wi*wi'; // mxm
vbar = vbar + wi; // mx1
endfor;
if rank(v/n-(vbar/n)*(vbar/n)') == cols(w);
iv = inv(v/n-(vbar/n)*(vbar/n)'); // mxm
else; "error 2";
iv = invswp(v/n-(vbar/n)*(vbar/n)');
endif;
retp(iv); endp;
proc weight1(n,t,w,t0); //analytic
local m,v,i,j,wi,wj,iv;
m = cols(w); // number of moments
v = zeros(m+2,m+2);
for i (1,n,1);
wi = zeros(t-t0+3,m+2);
wi[2:t-t0+2,2:m+1] = w[(i-1)*(t-t0+1)+1:i*(t-t0+1),.];
for j (1,t-t0+2,1);
wj = wi[j,.]'-wi[j+1,.]';
v = v + wj*wj'; // mxm
endfor;
endfor;
v = v[2:(m+1),2:(m+1)];
if rank(v/n) == cols(w);
iv = inv(v/n); // mxm
else; "error";
iv = invswp(v/n);
endif;
retp(iv); endp;
proc (1) = lagnmatrix(n,t,x,p);
local k,lx,i;
k = cols(x);
lx = zeros(n*t,k);
for i (1,k,1);
lx[.,i] = vec(lagn(reshape(x[.,i],n,t)',p)); // ntx1
endfor;
retp(lx); endp;
proc (1) = trimrmatrix(n,t,x,p,q);
local k,y,i;
k = cols(x);
y = zeros(n*(t-p-q),k);
for i (1,k,1);
y[.,i] = vec(trimr(reshape(x[.,i],n,t)',p,q));
endfor;
retp(y); endp;
//outputs:
proc (4) = printout(n,t,t0,w,dy,q,ththat1,z1,z2,Jhat1,_con);
local dumm1,z,lz,dz,tmp,dehat1,iv,Gb,h,kn,s,ds,i,si,Gr,
sb1,sg1,se1,k2,p,tht2hat,se2,bt1,phi1,p1,bse1,bt2,phi2,p2,bse2,bt,bse;
// *********************************** COVARIANCE MATRIX
dumm1 = (q.> ththat1[1]); " proportion of upper regime: " meanc(dumm1);"";
z = z2~(z1.*dumm1); // ntx[(1+k)+(1+k)+1]
tmp = packr(dz); // n(t-2)x[1+(1+k)+(1+k)]
dz = tmp[.,1:cols(tmp)]; // n(t-t0+1)x(1+k+1+1+k)
dehat1 = dy-dz*ththat1[2:rows(ththat1)]; // n(t-t0+1)x1
iv = weight(n,t,dehat1,w,t0);
Gb = -w'dz/n; // mx[(1+k)+(1+k)]
// *********************************** ds: n(t-2)x(1+k)
h = 1.06*stdc(packr(q))*n^(-0.2); // scalar, bandwidth
kn = exp(-(((ththat1[1]-q)/h).^2)/2)/sqrt(2*pi); // ntx1
s = z1.*kn; // ntx(1+k)
ds = zeros(n*(t-t0+1),cols(s)); // n(t-2)x(1+k)
for i (1,cols(s),1);
si = reshape(s[.,i],n,t)'; // txn
ds[.,i] = vec(trimr(si,t0-1,0)-trimr(si,t0-2,1)); // (t-2)x(1+k)
endfor;
Gr = -(w'ds/(n*h))*ththat1[3+k:rows(ththat1)]; // mx1
// *********************************** STANDARD ERROR
sb1 = inv(Gb'*iv*Gb-(Gb'*iv*Gr)*inv(Gr'*iv*Gr)*(Gr'*iv*Gb))/n;
sg1 = sqrt(1/(n*(Gr'*iv*Gr-(Gr'*iv*Gb)*inv(Gb'*iv*Gb)*(Gb'*iv*Gr))));
se1 = sg1|sqrt(diag(sb1));
" estimates and s.e. (threshold~lower regime (lag y,x)~delta (1,lag y,x)";
ththat1'|se1';
"";" upper regime estimates and s.e. (lag y,x)";
k2 = cols(z2);
if _con ==1; p = eye(k2)~zeros(k2,1)~eye(k2);
else; p = eye(k2)~eye(k2); endif;
tht2hat = (zeros(k2,1)~p)*ththat1;
se2 = p*sb1*p';
tht2hat'|sqrt(diag(se2))';
"";" Long-run parameter estimates and s.e.";
bt1 = ththat1[3:k2+1]; phi1=ththat1[2];
p1 = (eye(k2-1)~(bt1./(1-phi1)))./(1-phi1);
bse1=p1*sb1[2:k2+1,2:k2+1]*p1';
bt2 = tht2hat[2:rows(tht2hat)]; phi2=tht2hat[1];
p2 = (eye(k2-1)~(bt2/(1-phi2)))/(1-phi2);
bse2=p2*se2*p2';
bt = bt1|bt2; bse = sqrt(diag(bse1))|sqrt(diag(bse2));
bt'|bse';
"";" Overidentification J-statistic (p-value) " ;
Jhat1~cdfchic(Jhat1,cols(W)-rows(ththat1));
retp(se1,tht2hat~sqrt(diag(se2)),bt~bse,Jhat1~cdfchic(Jhat1,cols(W)-rows(ththat1)));
endp;
