changing sheet name in export
Posted: Fri Feb 01, 2019 10:54 am
I do want to load out-of-sample forecast generated by rats into our internal excel database.
However exporting the table with the forecast via report instruction creates an Excel file where the sheet name is 'sheet 1'.
Unfortunately this does not work with our database System, where aspecific sheet name is required.
Can I export a table via Report, copy or an other instruction, where i can define the sheet name?
Unfortunately this does not work:
report(action=show,format=xlsx,sheet=name1,unit=copy)
Thanks a lot
Thanks a lot
