Difference or not to difference variable in VAR
Posted: Tue Mar 26, 2019 11:03 am
You mentioned that variables should not be differenced as the transformation results in the lost information. But, I see many papers do or don't with very little explanation. If I estimate a VAR with mixed I(1) and I(0) without any transformation then it has been seen that the IRFs of I(1) variables are identical with that accumulated IRFs of the corresponding transformed variables.
So, what are the main points to justify difference or not to difference? (of course, Yoda - Yamamoto say we can augment an extra lag, but you commented that the true p is really unknown so that this trick will not always true). In the case, all I(1) are not cointegrated should we do difference?
Many thanks your help,
Best
Best
