How to plot IRF with MCprocessIRF
Posted: Mon Jul 01, 2019 11:14 am
It's seems that the topic has been already discussed before, but I don't udnertsand how to plot IRF for Markov-switching. I get a message error related to %%responses function. I tried to udnerstand what should I do but it doesn't work.
Is it possible to guide me and tell me what piece of code i should add into the program?
Thank you very much
here the code
Thank you very much
here the code
******************* MS-VAR procedure - EM estimation*********************
******************* Initialization
open data spread_d2.xlsx
calendar(d) 2010:01:21
allocate 2013:10:01
data(format=xlsx,org=col) 2010:01:21 2013:10:01
compute gstart=2010:01:21,gend=2013:10:01
set g = set
comp glab = %label(set)
@varlagselect(Lags=6,crit=hq)
# spx set
comp varlag = 1
******************* Estimation procedure
@mssysregression(states=2,switch=ch)
# spx set
# constant spx{1 to varlag} set{1 to varlag}
nonlin(parmset=regparms) betasys sigmav
nonlin(parmset=msparms) p
gset pt_t = %zeros(nstates,1)
gset pt_t1 = %zeros(nstates,1)
gset psmooth = %zeros(nstates,1)
@MSSysRegInitial gstart gend
frml logl = f=%MSSysRegFVec(t),pt_t1=%mcstate(p,pstar),$
pt_t=pstar=%msupdate(f,pt_t1,fpt),log(fpt)
maximize(start=(pstar=%MSSysRegInit()),parmset=regparms+msparms,$
method=bfgs,iters=500,pmethod=simplex,piters=5) logl gstart gend
****************** Graphical analysis
@%mssmooth p pt_t pt_t1 psmooth
set p1smooth = psmooth(t)(1)
set shade = p1smooth>=0.5
spgraph(header="France", vfields=3,hfields=2)
graph(footer="Smoothed Probability of Regime 1",max=1.0,min=0.0,shading=shade)
# p1smooth
graph(footer="SPX",shading=shade)
# spx
graph(footer="SET",shading=shade)
# set
****************** Save IRF's for regime 1
@MSSysRegSetModel(regime=1)
compute factor=%decomp(sigmav(1)),factor=factor*inv(%diag(%xdiag(factor)))
impulse(print,model=MSSysRegModel,results=impulses1,steps=10,factor=factor)
errors(print,model=MSSysRegModel,results=errors1,steps=10,factor=factor)
****************** Save IRF's for regime 2
@MSSysRegSetModel(regime=2)
compute factor=%decomp(sigmav(2)),factor=factor*inv(%diag(%xdiag(factor)))
impulse(print,model=MSSysRegModel,results=impulses2,steps=10,factor=factor)
errors(print,model=MSSysRegModel,results=errors2,steps=10,factor=factor)
******************** Graph IRF
@MCProcessIRF(model=MSSysRegModel,lower=lower,upper=upper,irf=irf)
spgraph(footer="",vfields=3,hfields=2,$
xlabels=||"Regime 1","Regime 2"||,ylabels=||"Cap Util","CPI","Oil Price"||)
do var=1,3
table(noprint) / lower(var,5) upper(var,5) lower(var,6) upper(var,6)
do shock=5,6
graph(row=var,col=shock-4,max=%maximum,min=%minimum,nodates) 3
# irf(var,shock)
# lower(var,shock) / 2
# upper(var,shock) / 2
end do shock
end do var
