Problem with optimisation
Posted: Thu Sep 12, 2019 5:17 pm
by PeterF
I tried to program in RATS a routine to perform non-linear Support Vector Regression (SVR). In order to obtain the fitted values for the dependent variable, the function L in the attached PDF document has to be maximized. The parameter epsilon has to be set and is the width of a range above and below the optimal fitted line for the dependent variable. The parameter C has also be set as a cost factor. k() is a kernel function. If an observation of y is within the band of plus and minus epsilon, then alpha and alpha-asterisk have to be zero.
i have written the following code
* First steps in developing the implementation of
* Support Vector Regression in RATS
* Gaussian RBF-Kernelfunction
function rbfkernel x1 x2 sigma
type real sigma
type real rbfkernel
type vector[real] x1 x2
local MATRIX[REAL] d
comp d = x1-x2
comp rbfkernel = exp(%dot(d,d)*-sigma)
* set-up the x and y vectors
declare vector[real] x(401) y(401) d(401)
do i=1, 401
   comp x(i) = -20.1+i*0.1
   comp y(i) = sin(x(i))/x(i)+ %ran(0.03)
comp y(201) = (y(200)+y(202))/2.0
* set the parameter for e-insensitive, cost and sigma (Gaussian kernel)
comp eps = 0.025
comp cost = 3
comp sigma = 0.05
* Trying find to estimate the alpha vectors
comp nrows = %rows(x)
declare vector[real] alpha(nrows) alphaast(nrows)
declare real costf1 costf2 coatf3 costfunc
nonlin(parmset=pars) alpha alphaast
nonlin(parmset=constraints) %sum(alpha-alphaast)==0.0 alpha>=0.0 alphaast>=0.0 $
      alpha<=cost alphaast<=cost
comp alpha = cost/2*%ones(nrows,1)
comp alphaast = cost/2*%ones(nrows,1)
find(parmset=pars+constraints,method=BFGS,iterations=100,cvcrit=0.1) maximum costfunc
comp costf1 = 0.0
comp costf2 = 0.0
comp costf3 = 0.0
 do i=1, nrows
    do j=1, nrows
       comp x1 = %xrow(X,i)
       comp x2 = %xrow(X,j)
       comp costf1 = costf1 + (alpha(i)-alphaast(i))*(alpha(j)-alphaast(j))*rbfkernel(x1,x2,sigma)
    comp costf2 = costf2 + (alpha(i)+alphaast(i))
    comp costf3 = costf3 + y(i)*(alpha(i)-alphaast(i))
comp costfunc = -0.5*costf1 - eps*costf2 + costf3
disp costfunc -0.5*costf1 -eps*costf2 costf3
Unfortunately, i do not get a solution. If I changed the method in the Find instruction then I get the error message ## M4. I have also tried to estimate the alpha vectors with quadratic programming and using either the LQPROG or the FIND instruction but had no success. What am I doing wrong? Or is it not possible to find the solution for the maximization problem? The function for the y-variable is from an example of a package in R and the fitted y-values were estimated within a second or two. I would appreciate it very much to receive an answer.
Best regards
PeterF
Re: Problem with optimisation
Posted: Fri Sep 13, 2019 10:55 am
First, as you've written that, COST is integer, which will throw off the calculations. Change that to compute cost=3.0.
Have you tried doing that for a more modest-sized grid? As you've written that, you have 800 parameters which will take a really long time to get anywhere. This is set up to handle different numers of grid points easily, and it seems to work for 41---you would have to check whether the results are what would be expected, but it does converge and satisfies the restrictions.
Support Vector Regression.RPF
(1.55 KiB) Downloaded 913 times
Posted: Fri Sep 13, 2019 12:48 pm
by PeterF
Dear Tom ,
thank you for your reply. I changed the computation of the cost variable to real and reduced the size of the x and y arrays to just 50 elements. Find with method BFGS delivered a solution, however, there were some elements of the alpha and alphaast vectors, which had a negative sign, which is not meeting the constraints.
For financial time series, 400 data points for daily or even weekly frequency does not appear to much. Would there be a more elegant and quicker way to solve the optimization of the l-function?
Best regards
PeterF
Posted: Fri Sep 13, 2019 1:24 pm
PeterF wrote:Dear Tom ,
Are they just "round-off" negative? If you are doing CVCRIT=.1, it's going to converge when some of those are still negative. I used a more natural CVCRIT and the negatives are all =.00000x (i.e. zero).
PeterF wrote: For financial time series, 400 data points for daily or even weekly frequency does not appear to much. Would there be a more elegant and quicker way to solve the optimization of the l-function?
Sometimes ideas don't scale well to larger data sets. However, isn't this a quadratic problem in the alpha's? The y and x are just data.
Posted: Fri Sep 13, 2019 2:04 pm
by PeterF
Tom,
yes, the negative values are just round-offs.
it could be formulated as a quadratic optimization.The Q-matrix contains the values of the k()-kernel functions. For the Find instruction I have no problem to set the constraints with nonlin. For the LQPROG instruction, i know how to formulate the constraint that the differences between alpha and alphaast sum up to zero. But how can i include the constraints that all elements are non-negative and smaller or equal to the value of the cost variable?
With the original size of x and y, i run quickly into the memory problem. Maybe it gets time for an upgrade to the pro version of RATS.
Best regards
Peter
Posted: Sat Sep 14, 2019 9:17 am
Non-negativity constraints are included by default. Upper bound would be A=identity, B=vector of constants at COST value. The quadratic form matrix would be
K -K
-K K
where K is the matrix of kernel weights.
Posted: Mon Sep 16, 2019 9:40 am
by PeterF
Tom,
thank you very much. For all the trees, I did not see the forest and overlooked that the solution is really not complicated as I supposed. I have written also some code lines for solving the quadratic programming instead of optimizing the L-function by applying the find instruction. It worked well and is much faster.
Best regards
PeterF
