Error in SVAR-GARCH code
Posted: Sun Feb 23, 2020 7:56 am
Dear Tom Doan
I have still the same error because of the code in the the example 11.2 SVAR_GARCH impulse response in RATS handbook for ARCH/GARCH and Volatility model(2nd Edition)
frml SAVRLogl = hh=SVARHMatrix(t),sqrthoil=sqrt(hh(t)(1,1)),$
ux=SVARUVector(t),%logdensity(hh,ux) [/b]
## SX11. Identifier SVARHMATRIX is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>l = hh=SVARHMatrix(<<<<
Common errors are
* a space before the ( in an option field
* a missing space before = in a SET or FRML
* a missing $ at the end of a long line which continues to the next
Please refer to the full text of coding below. And Please tell me what's wrong with below!
Common errors are
open data oildata.rat
calendar(q) 1974:1
data(format=rats,compact=average) 1974:01 2013:01 ipdm rac gdpmc1
* The difference in data preparation is that Elder and Serletis use * the final period within the quarter for the (monthly source) RAC,
* while this uses the quarterly average. The quarterly average
* matches the timing on GDP and the deflator.
* Data are annualized growth rates
set realoil = rac/ipdm
set oilgrow = 400.0*log(realoil/realoil{1})
set gdpgrow = 400.0*log(gdpmc1/gdpmc1{1})
compute nlags=4
set sqrthoil = 0.0
* Set up the VAR including the square root of oil (which will be
* generated recursively) as one of the regressors.
system(model=basevar)
variables oilgrow gdpgrow
lags 1 to nlags
det constant sqrthoil
* This is the position of the "M" effect coefficient
compute meffectpos=2*nlags+2
compute n=2
dec vect[series] y(n)
set y(1) = oilgrow
set y(2) = gdpgrow
* Estimate the OLS VAR
estimate(resids=u)
* Parameters for the GARCH processes for the orthogonal V *
dec vect[vect] g(n)
dec vect[vect] bvec(n)
dec vect[equation] garchmeqns(n)
do i=1,n
compute garchmeqns(i)=%modeleqn(basevar,i)
compute bvec(i)=%eqncoeffs(garchmeqns(i))
compute g(i)=||%sigma(i,i)*(1-.20-.60),.20,.60||
* B-matrix loading for the SVAR
dec frml[rect] bfrml
dec real b
frml bfrml = ||$
1.0,0.0|b,1.0||
compute b=0.0
nonlin(parmset=svarparms) bvec b
nonlin(parmset=garchparms) g
* Series for recursions on the variances
dec series[symm] vv
dec series[vect] hhd
dec series[symm] hh
dec rect binv
gset hhd 1 gend = %zeros(n,1)
gset hh 1 gend = %zeros(n,n)
gset vv 1 gend = %zeros(n,n)
* This is a "startup" function which needs to be executed at the
* start of a function evaluation. The B matrix and its inverse
* change with the parameters, but not with time. And we need to get
* the transformed pre-sample values.
function SVARStart
local symm vsigma
compute bmat=bfrml(1)
compute binv=inv(bmat)
compute vsigma=binv*%sigma*tr(binv)
gset hhd 1 gstart-1 = %xdiag(vsigma)
gset vv 1 gstart-1 = vsigma
* This is the function evaluated at each entry to compute the
* residuals. It also saves the outer product of the structural
* residuals for use in the GARCH recursion. *
function SVARUVector t
type vect SVARUVector
type integer t
local integer i
do i=1,%nvar
compute u(i)(t) = y(i)(t)-%eqnvalue(garchmeqns(i),t,bvec(i))
compute vv(t)=%outerxx(binv*%xt(u,t))
compute SVARUVector=%xt(u,t)
* This computes the logl likelihood by computing the covariance
* matrix, then the square root of the oil shock variance, then the
* residuals. It has to be done in that order since current sqrthoil
* is needed in the formula for the residuals.
