Rescale the SVAR IRFs to 1 unit shock
Posted: Wed Apr 01, 2020 3:53 pm
by BinhPham
I estimate an AB-type SVAR model in full-, first-half, and second-half samples.
I want to compare the IRFs of a specific variable between the three samples. Obviously, each sample gives a different standard deviation (diagonal elements of B-matrix).
Is it correct if I multiply the IRF and its error-bands of each estimation (sample) by 1/SD(shock) so that all IRFs have the same a unit shock? I think the linear structure gives it but not very sure because the error-bands are obtained from MC or bootstrap.
Thank you and best regards,
Re: Rescale the SVAR IRFs to 1 unit shock
Posted: Wed Apr 01, 2020 5:27 pm
It is true that shocks and error bands (whether done as standard errors or percentiles) scale. However, I'm not entirely sure what you are trying to do. In an A-B model, the shocks don't correspond 1-1 to variables. Are you trying to standardize on one particular shock having a unit impact on one particular target variable? What method are you using to do the error bands?
Posted: Wed Apr 01, 2020 6:08 pm
by BinhPham
I am comparing the AB-SVAR model IRFs, say, a shock to var X -> var Y. So, I have 3 samples, full, first 1/2, and half 1/2.
Now I have 3 IRFs set (only X -> Y). I want to standardize them because I want to see how different is a unit shock to X impact Y in each period?
I have MC integration IRFs. Could I rescale each IRF and error-bands with its StdDev? How about Delta Methods for the error bands?
Many thanks to your support
Posted: Wed Apr 01, 2020 7:46 pm
What is your structural model? As I said, in an SVAR the shocks don't correspond 1-1 to variables.
Posted: Thu Apr 02, 2020 11:08 am
by BinhPham
My SVAR is perhaps an A-model as, for example,
A = lower triangular matrix with 1's on main diagonal and other zero restrictions so that it is over-identifying.
B = diagonal matrix (*,0,0,0; 0,*,0,0; 0,0,*,0; 0,0,0,*)
So, parameters on B are size of shocks loaded.
I estimates the model in three episodes and want to compare, say, response of var 2 to a shock to var 3.
To make them comparable, I rescale the IRFs and error-bands by their B(i,i).
As you say there is no 1-1 relationship between shock and variable, what is a valid way to rescale the IRFs to a such 1 unit impulse?
I think if we pre-multiply inv(B)*A*u = e
Because B is diagonal so that we can rescale to a unit impulse. Is it correct?
Many thanks for your help,
Posted: Thu Apr 02, 2020 4:42 pm
Your model is a restricted Cholesky factor, which is a much more accurate description of what you're doing than A-B SVAR. Because of the recursive definition, you can, indeed, associate the shocks 1-1 with the variables. You can transform a factor (f) to unit impacts with something like:
compute f=%ddivide(f,%xdiag(f))
Note that you can use the Waggoner-Zha sampler for a restricted Cholesky factor.
Posted: Thu Apr 02, 2020 6:27 pm
by BinhPham
Thank you Tom!
