Understanding the dofor loop
Posted: Fri Nov 20, 2020 2:48 pm
by AdamElderfield
I'm very new to RATS so I apologise for the "newbie" question - hopefully these will become less frequent (or more interesting) as I become more acquainted with the software.
I'm trying to do something rather simple, loop over a variables and detrend them
dofor y = lgdpus lgdp ltot rus lxgs lgne lrtwi rcash cinfl lausq lusq
FILTER(REMOVE=TREND) y / y_DT
end dofor y
Unfortunately, this doesn't produce the detrended series. I'm obviously missing some important syntax here, I've looked in the user guide but can't seem to find my answer.
I understand the logic, so my guess is that I am not declaring y properly. But I am not sure how to fix this, I tried
dofor [string] y = "lgdpus" "lgdp" "ltot" "rus" "lxgs" "lgne" "lrtwi" "rcash" "cinfl" "lausq" "lusq"
end dofor y
But this gave me an error:
## SX22. Expected Type INTEGER, Got STRING Instead
>>>>ring] y = "lgdpus" <<<<
Any pointers would be much appreciated!
Adam
Re: Understanding the dofor loop
Posted: Fri Nov 20, 2020 3:22 pm
The %L function gives the name of a series as a string, and %S can be used to create a new series from a string. So (if I understand what you want), you would do
FILTER(REMOVE=TREND) y / %s(%l(y)+"_DT")
end dofor y
which will give you lgdpus_dt, lgpd_dt, etc. as the detrended series.
Posted: Fri Nov 20, 2020 7:40 pm
by AdamElderfield
Thanks Tom - that is exactly what I am after.
Posted: Fri May 28, 2021 11:44 pm
by AdamElderfield
Another question - this one seems simple, but I can't get it to work.
I want to loop over some parameters and set their staring values
dofor y = L_ar1 L_ar12 L_ar13 S_ar1 S_ar12 S_ar13 C_ar1 C_ar12 C_ar13 L_ar1 L_ar12 L_ar13
compute y = 0.5
end dofor y
I get the following error
## SX22. Expected Type INTEGER, Got REAL Instead
>>>>dofor y = L_ar1 <<<<
I use this kind of loop all the time (in other programs. So would be good to understand what I am doing wrong here.
Posted: Sat May 29, 2021 8:45 am
The DOFOR index is (by default) integer. If you want to loop over some other type of object, you need to declare it. This should work:
declare real y
compute y = 0.5
end dofor y
Posted: Sat May 29, 2021 4:18 pm
by AdamElderfield
Great thanks! Kind of obvious now you point that out.
While that got rid of the error, I don't think I am solving my problem of setting starting values of my parameters:
* Declare parameter set
nonlin(parmset=NSA_MODEL) lambda L_ar1 L_ar12 L_ar13 S_ar1 S_ar12 S_ar13 C_ar1 C_ar12 C_ar13 L_ar1 L_ar12 L_ar13 sigL sigS sigC cvLS cvLC cvSC sigbe10 sigbie3 sigcie1 sigme1 sigme2 siguie1 siguie2
compute lambda = 0.03
declare real y
compute y = 0.5
end dofor y
dofor y = sigL sigS sigC cvLS cvLC cvSC sigbe10 sigbie3 sigcie1 sigme1 sigme2 siguie1 siguie2
compute y = 0.1
end dofor y
display NSA_MODEL
And the result from the display command:
LAMBDA 0.03
L_AR1 NA
L_AR12 NA
L_AR13 NA
S_AR1 NA
S_AR12 NA
S_AR13 NA
C_AR1 NA
C_AR12 NA
C_AR13 NA
L_AR1 NA
L_AR12 NA
L_AR13 NA
SIGL NA
SIGS NA
SIGC NA
CVLS NA
CVLC NA
CVSC NA
SIGBE10 NA
SIGBIE3 NA
SIGCIE1 NA
SIGME1 NA
SIGME2 NA
SIGUIE1 NA
SIGUIE2 NA
So looks like I am setting lambda with my direct call to compute, but the loops are not working?
Posted: Sun May 30, 2021 11:53 am
The DOFOR uses those as inputs, not outputs, so all the DOFOR loops are doing is setting (and promptly forgetting) a value for Y.
compute L_ar1=L_ar12=L_ar13=S_ar1=S_ar12=S_ar13=C_ar1=C_ar12=C_ar13=L_ar1=L_ar12=L_ar13=.5
will do what intended your first DOFOR loop to do.
