Near VAR estimation
Posted: Fri Nov 20, 2020 10:32 pm
by AdamElderfield
I am estimating a var with lag restrictions, what I believe is called a near VAR, I'm using iterative SUR which as I understand is the correct estimation method for this problem. Interestingly, it works fine if I don't specify the iteration numbers:
* Estimate with SUR
sur(model = restricted_var, cvout = restr_sig)
But when I specify the iteration numbers
* Estimate with SUR
sur(model = restricted_var, cvout = restr_sig, iter = 20)
I get the following error message
## REG13. Singular Regressions - Check for Collinearity among Rows 1 to 85.
I've tracked it to 11 iterations before this error pops up. I'd love to understand what is happening at iteration 12 to cause my regressors to suddenly become colinear (probably showing my lack of understanding here)
The system I am estimating is below (I can upload the data / full program if it helps?)
* Estimate restricted model with SUR. To do so, we set up a near-VAR using EQUATION and GROUP commands
EQUATION usgdp_eq lgdpus_dt
# lgdpus_dt{1 to 3} rus_dt{1 to 3}
EQUATION tot_eq ltot_dt
# lgdpus_dt{1 to 3} ltot_dt{1 to 3} rus_dt{1 to 3}
EQUATION rus_eq rus_dt
EQUATION usq_eq lusq_dt
# lgdpus_dt{1 to 3} rus_dt{1 to 3} lusq_dt{1 to 3}
EQUATION xgs_eq lxgs_dt
# lgdpus_dt{1 to 3} ltot_dt{1 to 3} lxgs_dt{1 to 3}
EQUATION ausq_eq lausq_dt
# lgdpus_dt{1 to 3} ltot_dt{1 to 3} rus_dt{1 to 3} lusq_dt{1 to 3} lausq_dt{1 to 3} lgne_dt{1 to 3} lgdp_dt{1 to 3} $
   cinfl_dt{1 to 3} rcash_dt{1 to 3} lrtwi_dt{1 to 3}
EQUATION gne_eq lgne_dt
#  ltot_dt{1 to 3} lausq_dt{1 to 3} lgne_dt{1 to 3} lgdp_dt{1 to 3} cinfl_dt{1 to 3} rcash_dt{1 to 2} lrtwi_dt{1 to 3}
EQUATION gdp_eq lgne_dt
# lgdpus_dt{1 to 3} ltot_dt{1 to 3} lxgs_dt{1 to 3} lausq_dt{1 to 3} lgne_dt{1 to 3} lgdp_dt{1 to 3} cinfl_dt{1 to 3} rcash_dt{1 to 2} lrtwi_dt{1 to 3}
EQUATION cinfl_eq cinfl_dt
# ltot_dt{1 to 3} lgne_dt{1 to 3} cinfl_dt{1 to 3} rcash_dt{1 to 3} lrtwi_dt{1 to 3}
EQUATION rcash_eq rcash_dt
# lgne_dt{1 to 3} cinfl_dt{1 to 3} rcash_dt{1 to 3} lrtwi_dt{1 to 3}
EQUATION rtwi_eq lrtwi_dt
* put into group
GROUP restricted_var usgdp_eq tot_eq rus_eq xgs_eq ausq_eq gne_eq gdp_eq cinfl_eq rcash_eq rtwi_eq
Adam
Re: Near VAR estimation
Posted: Sat Nov 21, 2020 9:07 am
Yes, the data and whole program would help. How many observations do you have? Offhand, it doesn't seem that there's anything wrong with the structure.
Posted: Sat Nov 21, 2020 5:05 pm
by AdamElderfield
Thanks Tom - will do. Although I need re-write the program, when I closed RATS last night I was prompted to save "filename".rpf. Naturally, I clicked yes not realising that this saved over my input file with the outputs... I'll try and re-create the error and send it via email.
Cheers
Adam
Posted: Sat Nov 21, 2020 5:45 pm
by AdamElderfield
I have attached the files in this post (I mentioned I would email them, but this is easier). Also, my previous post about the input saving over the output, I think I had accidentally saved the output file with the input name - whoops.
There are 136 observations in the model.
Thanks for taking a look.
Adam
Posted: Sat Nov 21, 2020 9:47 pm
You have a typo on the dependent variable on one of these:
They have the same dependent variable. Because the explanatory variables are different, it takes a while before the process collapses.
Posted: Sun Nov 22, 2020 1:42 am
by AdamElderfield
Wow - this is a little embarrassing. Thanks for picking that up Tom, appreciate it!
Hopefully I won't bother you with such silly problems in future!
