Automatisation of data exporting
Posted: Thu Jan 14, 2021 2:50 pm
I conduct a repeated analysis for several dates (around 100). The output of each analysis are nine distinct series.
I would like to do either one of the following two tasks within a loop, which iterates over all dates:
1. for each iteration I want to export all nine series to an xls or xlsx or csv file which is named like this: results_2019_12_31.csv, results_2020_01_01.csv, ...... (or .xslsx/.xls files)
or
2. for each iteration I want to rename all nine series in the following way: Series1_2019_12_31, Series2_2019_12_31, ... , Series9_2019_12_31. Then I want to add all nine series to a data structure that is appened on each iteration by the nine new results. Finally I want to export that data structure to a .xls or .xlsx or .csv file.
Both alternatives are fine for me. Could you give some advice?
Thank you in advance
Best
Jules
or
Best
Jules
