Residuals vs. Standardized Residuals
Posted: Tue Apr 06, 2021 5:36 am
As per PRJ https://estima.com/ratshelp/index.html? ... ction.html, to calculate standardized residuals after a LINREG is
I can get identical results via
However, sometimes after a BOXJENK, the former PRJ technique results in NA's, whereas the latter doesn't. Why?
Standardized residuals make it easier to view outliers:
(a) Should there be a comparison of both residuals and standardized residuals after a LINREG or BOXJENK via plots: line graph, histogram, acf & pacf, or just the standardized residuals?
(b) Are the standard diagnostic tests after a LINREG e.g. for heteroskedasticity (Breusch-Pagan-Godfrey, White's), autocorrelation (Durbin's H, Breusch-Godfrey), also valid after a BOXJENK, and if not, why not?
Cheers,
Amarjit
prj(xvx=px)
set stdresids = resids/sqrt(%seesq*(1-px))
graph(style=symbols,vlabel="Standardized Residual")
# stdresids
stats resids
set stdresids_2 = (resids - %mean) / sqrt(%variance)
prin / stdresids stdresids_2
Cheers,
Amarjit
