Inflation expectations dynamic factor model
Posted: Sun May 30, 2021 5:38 pm
by AdamElderfield
I am trying to apply a Aruoba's term structure of inflation expectations model (https://www.philadelphiafed.org/-/media ... 33C0BBF827) to Australian inflation expectations data.
I am running into a couple of problems with my DLM instruction:
## DLM2. No Observations Produce Valid Output. Check Data and Initial Values
While quite informative, I am not sure what I should be checking. It could be my starting values for my parameters, although I wouldn't say they are completely un-reasonable.
I was hoping someone could provide some guidance on how to proceed. I've attached my code and data below. Note, my data has quite a few missing observations, although this is something that the KF should be able to handle. In any case, I did try a version with data backcast, but still had no success.
INFE RATS.RPF
Program for INFE model
(5.39 KiB) Downloaded 1500 times
RBA_INFE.csv
Data for INFE model
(8.55 KiB) Downloaded 1538 times
Adam
Re: Inflation expectations dynamic factor model
Posted: Mon May 31, 2021 4:30 pm
by AdamElderfield
Turns out my starting values were quite the problem.. I have had some success with getting the model to estimate, not converge, by changing these.
Posted: Mon Oct 31, 2022 2:33 pm
by economics99
Adam,
Did you manage to fix your code?
Raf
