impulse response
Posted: Fri Jul 30, 2021 5:03 pm
by atarca
Is it possible to use the EXPORT option of @CATS in order to obtain the impulse-response graphs by the below procedures?
@mcvardodraws(model=CatsModel)
@mcgraphirf(model=CatsModel,page=one,varlabels=vlabels,shocklabels=vlabels, center=median,percent=||.025,.975||)
Or is there any other way to obtain them with bands?
Tarkan
Re: impulse response
Posted: Tue Aug 03, 2021 12:39 pm
CATS just does point estimates. One problem with doing Monte Carlo integration with cointegrated models is that the "beta" has a non-standard conditional distribution. If you're willing to take beta as given the remainder of the parameters can be handled using standard techniques---see the MONTEVECM.RPF example. Making beta also unknown requires Gibbs sampling.
Posted: Sat Aug 21, 2021 6:51 am
by atarca
TomDoan wrote:CATS just does point estimates. One problem with doing Monte Carlo integration with cointegrated models is that the "beta" has a non-standard conditional distribution. If you're willing to take beta as given the remainder of the parameters can be handled using standard techniques---see the MONTEVECM.RPF example. Making beta also unknown requires Gibbs sampling.
Thank you very much for your explanations, Tom.
Cheers
Tarkan
