Page 1 of 2
Time Varying Parameter model
Posted: Mon Aug 24, 2009 9:52 pm
by ivory4
Single equation Time varying parameter model, estimated using kalman filter.
y_t=x_tb_t+u_t,
b_t=b_t-1+v_t,
Var(u_t)=R,
Var(v_t)=Q,
User Guide provides an example for VAR, is there one for a single equation?
Re: How estimate a TVP model?
Posted: Mon Aug 24, 2009 10:52 pm
From the Tsay textbook examples - tsayp510.prg and tsayp533.prg. From the West and Harrison textbooks examples, westp081.prg.
Posted: Mon Aug 31, 2009 5:09 pm
by ivory4
I have some questions about the code.
1. What is the function for line: nonlin leps leta?
I have the RM at hand and it says that nonlin set a list of free parameter before using DLM, and what does this mean?
2. sv=1.0 in this code, are they pegging the sv or using 1.0 as initial value?
When I change the sv, the estimation is changed, but if it is just initial value, the estimation should not change much.
Thanks for reading and replying.
* Example 11.2, pp 533-535
open data m-fac9003.txt
calendar(m) 1990
data(format=free,org=columns) 1990:1 2003:12 aa age cat f fdx gm hpq kmb mel nyt pg trb txn sp
set gm = gm*.01
set sp = sp*.01
* Fixed coefficients model done with linreg
linreg gm
# constant sp
* Done with DLM. sv=1.0 with VAR=CONCENTRATE concentrates out the variance of the
* measurement equation. FREE=2 has no effect on the estimates, but corrects the
* likelihood function so it matches LINREG's by computing the likelihood
* conditional on the (freely estimated) coefficients.
dlm(y=gm,c=||1.0,sp||,sv=1.0,var=concentrate,exact,free=2,type=smoothed) / xstates vstates
* With the smoothed estimates, the state means and variances are the same for all
* time periods. Note that the %VARIANCE (the concentrated estimate of the
* measurement equation variance) isn't corrected for degrees of freedom, while the
* calculation used in the text is.
disp xstates(2003:12)
disp tr(%sqrt(%xdiag(vstates(2003:12))*%variance))
* Now estimate the component variances. Note that we're pegging sv=1.0 and using
* var=concentrate to  concentrate out the unknown measurement variance. The other
* variance estimates will have to be multiplied by %VARIANCE to get their true
* estimated values. In component models like this, it can be very difficult to
* estimate all the variances directly because they are so highly correlated. In
* this case, the estimates given in the book aren't really the correct likelihood
* maximizers. The likelihood is a bit higher with a somewhat higher variance on
* beta.
nonlin leps leta
compute leps=leta=0.0
dlm(y=gm,c=||1.0,sp||,sv=1.0,var=concentrate,sw=%diag(||exp(leta),exp(leps)||),$
   exact,method=bfgs,type=smoothed) / xstates vstates
disp "Component Std Dev"
disp "Measurement" @20 sqrt(%variance)
disp "Alpha" @20 sqrt(%variance*exp(leta))
disp "Beta" @20 sqrt(%variance*exp(leps))
set alpha = xstates(t)(1)
set beta  = xstates(t)(2)
set expret = %dot(||1.0,sp||,xstates)
spgraph(hfields=2,vfields=2,footer="Figure 11.5 Time plots from a time-varying CAPM")
graph(hlabel="Excess return")
# gm
graph(hlabel="Expected return")
# expret
graph(hlabel="Alpha")
# alpha
graph(hlabel="Beta")
# beta
Posted: Thu Sep 03, 2009 1:36 pm
The first DLM has the coefficients "fixed" - they follow a random walk with zero increment variance (there's no SW option). The only reason the estimates change over the sample is that you get more information. When you Kalman smooth (as opposed to filter), the coefficients will be the same across the sample. In the second case, they follow a RW with a non-zero variance; the "target" can change over the course of the sample. As you can see from the formula for SW, leta is the log of the increment variance for the constant, and leps is the log of the increment variance for the beta coefficient. The second DLM estimates those by maximum likelihood.
nonlin leps leta
There are actually three variances in this model - the two in the SW matrix and variance in the measurement error. sv=1.0,var=concentrate does the estimation by concentrating out a scale factor in the variances. This is described in the User's Guide. If you change this to (say) sv=2.0,var=concentrate, you'll get (exactly) the same results for xstates; the SW variances will go up by a factor of 2, which means that leps and leta will increase by log(2). There is, however, no reason to change sv=1.0 if you use var=concentrate. The alternative way of handling this is to put the variance of the measurement error itself into the parameter set:
nonlin lsigma leps leta
compute leps=leta=lsigma=0.0
dlm(y=gm,c=||1.0,sp||,sv=exp(lsigma),sw=%diag(||exp(leta),exp(leps)||),$
Posted: Fri Jan 29, 2010 7:29 am
by ivory4
In my model, xstates should be 375x5, then I set as following
set intercept = xstates(t)(1)
But it tells me "SX22. Expected Type SERIES, Got REAL Instead"
What is the correct way of reading the estimated time varying coefficients out?
The part of code after inputting data is as following.
And also if I would like to graph those estimates, is that the correct way?
compute leps1=leps2=leps3=leps4=leps5=lsigma=0.0
dlm(y=ue,c=||1.0,def,ygap,ue1,ue2||,sv=exp(lsigma),sw=%diag(||exp(leps1),exp(leps2),exp(leps3),exp(leps4),exp(leps5)||),$
disp "Beta" @20 sqrt(%variance*exp(leps2))
set gama  = xstates(t)(3)
set row1  = xstates(t)(4)
spgraph(hfields=2,vfields=2,footer="Figure ")
graph(hlabel="intercept")
# intercept
graph(hlabel="beta")
# beta
graph(hlabel="gamma")
# gama
graph(hlabel="row1")
# row1
Posted: Fri Jan 29, 2010 11:01 am
ivory4 wrote:In my model, xstates should be 375x5, then I set as following
Based upon the error message, it looks as if BETA is used as a REAL earlier in the program.
ivory4 wrote: And also if I would like to graph those estimates, is that the correct way?
That looks fine.
Posted: Fri Jan 29, 2010 11:27 am
by ivory4
cal 1972 8 12
allocate 0 2003:12
open data "C:*******.xls"
data(format=xls,org=col) / ue def ygap ue1 ue2
nonlin leps1 leps2 leps3 leps4 leps5 lsigma
disp "Alpha" @20 sqrt(%variance*exp(leps1))
disp "Gap"  @20 sqrt(%variance*exp(leps3))
disp "Row1" @20 sqrt(%variance*exp(leps4))
disp "Row2" @20 sqrt(%variance*exp(leps5))
# intercept
# beta
# gama
# row1
Error message
## SX22. Expected Type SERIES, Got VECTOR Instead
>>>>set intercept <<<<
This means that I am not recording the results in a correct way.
Posted: Fri Jan 29, 2010 2:46 pm
ivory4 wrote:Error message
>>>>set intercept <<<<
If you tried writing this with INTERCEPT as a VECTOR and then tried to re-run it with it as a SERIES without clearing the program first, that's what will happen. Before re-running a program after you make a change like that, hit the "Clear Program" toolbar button first (far right button). That clears out the symbol table so you don't have conflicts.
As you have this written, the measurement error variance will be exp(lsigma). It's %variance only if you peg SV at 1.0 and use VAR=CONCENTRATE. If you have modelled all the variances (which you've done here), take the %variance* out of all of those other calculations like the value for ALPHA. You just want sqrt(exp(leps1)).
Posted: Mon Feb 01, 2010 1:40 am
by ivory4
compute leps1=leps2=leps3=leps4=leps5=lsigma=log(0.01)
If I set type=smoothed, the states are too close to each other, like
1998:06 0.095926629962
1998:07 0.095926629961
What would be a solution?
I tried to use estimated hyperparameter, I need to manually add those number to COMPUTE and run dlm again?
Re: About DLM Instruction
Posted: Mon Feb 01, 2010 9:55 am
That would happen if the variance on one of the "w" terms goes (effectively) to zero, which would probably mean an estimated log variance of maybe -15 or smaller. With that many coefficients, I'm not surprised that at least one of the coefficients would behave that way.
Note, however, that I don't think you get good results freely estimating the variances in a model like this. There's a tendency for the maximum likelihood estimates to have a few of the regression coefficients moving dramatically to fit the data almost exactly. Something more tightly parameterized (for instance, having the SW matrix be a single scale parameter x a fixed matrix) tends to work better.
Posted: Mon Feb 01, 2010 3:23 pm
by ivory4
TomDoan wrote:That would happen if the variance on one of the "w" terms goes (effectively) to zero, which would probably mean an estimated log variance of maybe -15 or smaller. With that many coefficients, I'm not surprised that at least one of the coefficients would behave that way.
That is correct, the variance is very very small.
TomDoan wrote: Note, however, that I don't think you get good results freely estimating the variances in a model like this. There's a tendency for the maximum likelihood estimates to have a few of the regression coefficients moving dramatically to fit the data almost exactly.
And I think the intercept is somehow large to be intuitively consistent with my model and I think it take away the variance in the coefficients.
TomDoan wrote: Something more tightly parameterized (for instance, having the SW matrix be a single scale parameter x a fixed matrix) tends to work better.
In the workbook, 3.2 method 4?
Measurement variance concentrated out; ratio in log form?
Posted: Mon Feb 01, 2010 4:40 pm
Time-varying coefficients models are particularly tricky because there isn't likely to be as much prior knowledge to set the variances as there will be for the unobservable components models. Even in the case of a time-varying beta, where you at least have a good idea that the value is likely to be somewhere in the range of 0 to 2, the combination of the variances might produce results which look "wrong". This is from Tsay's textbook (tsayp505.prg, the data file is attached):
calendar(m) 1990
data(format=free,org=columns) 1990:1 2003:12 aa age cat f fdx $
compute sv=0.1**2,seta=0.02**2,seps=0.04**2
* The above values are quite far from the ones which maximize the
* likelihood. Note that the "C" matrix is actually a time-dependent
* formula, since it includes a reference to the series "sp"
dlm(y=gm,c=||1.0,sp||,sv=sv,sw=%diag(||seta,seps||),exact,type=smoothed) / xstates vstates
linreg gm
# constant sp
set tvbeta = xstates(t)(2)
graph(vgrid=%beta(2),footer="Smoothed estimates of time-varying betas")
# tvbeta
The seps (which is the variance on the change in the beta coefficient) is .04^2. The coefficient follows a random walk, so that would give a variance of .04^2 x 168=.27 over the course of the sample. That doesn't seem at all unreasonable. However, if you look at the results, the beta's are flying all over the place; making the estimation worthless. What's wrong? The measurement equation variance of .1^2. The data set has returns multiplied by 100 to make percentages. The .1^2 (and the value for seta as well) are scaled for data in fractions. With the values of the data in the data set being enormous relative to that .1^2, it becomes much "cheaper" to explain the data by moving the beta around than to assign the error to the measurement equation. Hence the wild betas. If you correct the scales on the sv and seta to:
compute sv=10.0**2,seta=2.0**2,seps=0.04**2
you get much more reasonable results, though you might find that to be "too" stiff.
West and Harrison offer what may be a better way to handle TVC models, although it doesn't seem to have really caught on. Instead of adding variance to the state equation at each time period, it multiplies the last period variance by a constant somewhat larger than 1. (It's specified as a "discount" parameter; the reciprocal of that multiplier). You can try this instead, and see the sensitivity to the choice of discount.
dlm(y=gm,c=||1.0,sp||,sv=sv,discount=.99,exact,type=smoothed) / xstates vstates
m-fac9003.txt
(16.41 KiB) Downloaded 1705 times
Posted: Mon Feb 01, 2010 11:49 pm
by ivory4
TomDoan wrote:Time-varying coefficients models are particularly tricky because there isn't likely to be as much prior knowledge to set the variances as there will be for the unobservable components models. Even in the case of a time-varying beta, where you at least have a good idea that the value is likely to be somewhere in the range of 0 to 2, the combination of the variances might produce results which look "wrong". This is from Tsay's textbook (tsayp505.prg, the data file is attached):
calendar(m) 1990
linreg gm
# constant sp
# tvbeta
m-fac9003.txt
These two are very useful and generate "better reasonable" results.
Thank you for information. I may follow up more.
Re: Time Varying Parameter model (was "About DLM Instruction")
Posted: Tue Mar 02, 2010 3:42 am
by ivory4
## SR5. Using Range -32765 to -32765 of Series BETA. (Incorrect start,end or SMPL)
Why this may happen from time to time? When I use "Clear program", sometimes it could be solved sometimes not and I have to restart the application.
The program I am running is only slightly different from what we discussed here.
Posted: Tue Mar 02, 2010 10:50 am
It's hard to tell without seeing the exact program. However, if you run part of a program, you might start at a spot which leaves some variable uninitialized or set to a value from later in the program when it needs the values from the start.
