Page 1 of 2
Mountford & Uhlig JAE 2009 replication files
Posted: Tue Aug 25, 2009 10:39 am
mountforduhligjae2009.zip has replication files for Mountford & Uhlig(2009), "What are the Effects of Fiscal Policy Shocks?",
Journal of Applied Econometrics, vol 24, 960-992. This identifies multiple shocks with and without delay (zero) constraints.
The methods used in this are described in detail as part of the
Vector Autoregressions e-course.
Detailed description
Re: Mountford & Uhlig JAE 2009 replication files
Posted: Tue Dec 15, 2009 8:39 am
by lhlee0506
Thank you very much.
But mu2009b2.prg needs to add one line: source mujaesetup.src.
Please please instruct me
1.how to modify mu2009b1.prg to compute forecast error variance decomposition?
2.how to modify mcgraphirf.src to show the sign restrictions on the impulse responses?
Best regards.
Posted: Tue Dec 15, 2009 12:54 pm
I'm not sure what you mean by 2.
Posted: Wed Dec 16, 2009 4:49 am
by lhlee0506
For example, the government spending shock requires the government spending increases for 4 periods, then you will see a line on the period 4 in
impulse response of government spending.
Posted: Wed Dec 16, 2009 2:20 pm
That would be done with a GRID=(T==KMAX) or a SHADING=(T<=KMAX) option on GRAPH.
The IRFSQUARED's are already being computed in the code, so you would just add the same code as is done in the
Uhlig JME replication to do the variance decomposition.
Posted: Thu Dec 17, 2009 4:36 am
by lhlee0506
Thanks for your reply.
But I still can't figure out how to add GRID=(T==KMAX) or a SHADING=(T<=KMAX) on the graph into the code_mcgraphirf.src as followed.
especially when we just wanna grid the response of variable 2 in the impulse response graph of government spending shock, grid the response of variable 1, 3, 8, 9 in the impulse response graph of business cycle shock. how can we make it?
* @MCGraphIRF(model=model used in generating responses,other options )
* Graphs error bands for impulse response functions using the
* information already computed in %%responses. These can be calculated
* using @MCVARDoDraws or some similar procedure.
* %%responses should have the following structure:
* the number of draws is NDRAWS,
* the number of steps is NSTEPS
* the number of variables is NVAR and
* the number of shocks is NSHOCKS.
* (NSHOCKS often is equal to NVAR, but doesn't have to be).
* %%responses is a VECT[RECT] with outer dimensions NDRAWS. Each draw is
* represented by a RECT array, with NVAR*NSHOCKS rows and NSTEPS
* columns. The rows are blocked by shocks so the first set of NVAR
* elements in a column are the responses to the first shock, the second
* set are the responses to the second shock. If you %VEC a set of
* impulse responses produced by IMPULSES, that's how they will be
* blocked.
* Options:
* MODEL=model used in generating responses
* SHOCKLABELS=VECT[STRINGS] of labels for the shocks [dependent variables of model]
* VARLABELS=VECT[STRING] of labels for the variables [dependent variables of model]
* INCLUDE=||list of dependent variables to show (in order, by position in model)|| [all]
* INCLUDE can be used to eliminate some variables which aren't of
* special interest or to rearrange the panes on a graph. For instance,
* in a 6 variable VAR, INCLUDE=||6,1,3,4|| will show only the responses
* of those four variables (based upon their positions in the model) and
* will put the 6th variable in the top left.
* CENTER=[MEAN]/MEDIAN/INPUT
* IMPULSES=RECT[SERIES] of central impulse responses for the graph
* This chooses what is shown as the "estimate" of the IRF. MEAN and
* MEDIAN are the mean and median of the drawn responses. INPUT means
* that you are including an IMPULSES option with RECT[SERIES] which are
* to be used. This needs to be in the format created by the IMPULSE
* instruction.
* PERCENTILES=||percentiles for lower and upper bounds|| [||.16,.84||]
* STDDEV=# of standard deviations from mean for lower and upper bounds [not used]
* STDDEV is used for doing error bands based upon multiples of the
* sample standard deviations. For instance, STDDEV=1.0 will give upper
* and lower bounds that are one standard deviation above and below the
* central response. PERCENTILES is the default.
* HEADER=' title for graph '
* FOOTER=' footer for graph '
* PAGE=[ALL]/ONE/BYSHOCK/BYVARIABLE
* COLUMNS=# of columns on a page [depends upon number of graphs]
* The PAGE option selects the layout of a single page of graphs.
* PAGE=ALL (the default) does all responses to all shocks on a single
* page (shocks in columns, dependent variables in rows). Note that the
* panes get a bit small when you get more than four variables.
* PAGE=ONE does one combination of shock and variable per page.
* PAGE=BYSHOCK does a separate page for each shock, with all responses
* arranged in one or more columns.
* PAGE=BYVARIABLE does a separate page for each variable, with all
* shocks arranged in one or more columns.
* Revision Schedule:
* 06/2009 Stripped from montevar.src procedure. Options added.
procedure MCGraphIRF
option model model
option vect[strings] shocklabels
option vect[strings] varlabels
option vector percentiles ||.16,.84||
option real stddev
option choice center 1 mean median input
option rect[series] impulses
option string header
option string footer
option choice page 1 all one byshock byvariable
option integer columns
option vect[integer] include
local vect[integer] grparms
local vect[strings] xlabel ylabel
local vect[integer] depvars yshow
local integer draws steps nshocks nshow npercent
local vect[series] upper lower upperx lowerx resp
local real minlower maxupper sigma
local integer i j k
local vector work
local vector frac
local integer ntargets pages nvert nhorz pagetoshow
local integer shocklower shockupper varlower varupper
local string gheader
local vect request
declare vect[rect] %%responses
if %rows(%%responses)==0 {
disp "####@MCGraphIRF - needs procedure to draw responses first (%%responses not defined)"
return
if .not.%defined(model) {
disp "Syntax: @MCGraphIRF(model=model used in generating responses,other options)"
return
if center==3.and..not.%defined(impulses) {
disp "####@MCGraphIRF(CENTER=INPUT) needs IMPULSES option"
return
* Take the number of variables (targets) out of the model
compute ntargets=%modelsize(model)
* Hack the dimensions of everything else out of the <<%%responses>> array
compute draws=%rows(%%responses)
compute steps=%cols(%%responses(1))
compute nshocks=%rows(%%responses(1))/ntargets
dim work(draws)
* Set up the labels for the matrix of graphs
compute depvars=%modeldepvars(model)
if %defined(include)
compute nshow=%rows(include),yshow=include
else
compute nshow=ntargets,yshow=%seq(1,nshow)
dim xlabel(nshocks) ylabel(nshow)
if %defined(shocklabels)
ewise xlabel(i)=shocklabels(i)
else
ewise xlabel(i)=%l(depvars(i))
if %defined(varlabels)
ewise ylabel(i)=varlabels(yshow(i))
else
ewise ylabel(i)=%l(depvars(yshow(i)))
* Save the graph parms and reset the sizes
compute grparms = %grparm()
grparm(bold) hlabel 18 matrixlabels 14
grparm axislabel 24
* Figure out how many percentiles we need, combining the requests from
* the bands (in percentiles option) and center (if median).
dim request(0)
compute npercent=0
if %defined(percentiles).and..not.%defined(stddev)
compute npercent=%rows(percentiles)
if center==2 {
if npercent>0
compute request=percentiles~~||.50||
else
compute request=||.50||
else
if npercent>0
if page==1
compute pages=1,nvert=nshow,nhorz=nshocks
else
if page==2
compute pages=nshow*nshocks,nvert=nhorz=1
else
if page==3 {
compute pages=nshocks
if %defined(columns).and.columns>0
compute nhorz=columns
else
compute nhorz=fix(sqrt(nshow))
compute nvert=(nshow-1)/nhorz+1
else
if page==4 {
compute pages=nshow
else
compute nhorz=fix(sqrt(nshocks))
compute nvert=(nshocks-1)/nhorz+1
dim upper(nshocks) lower(nshocks) resp(nshocks)
if npercent>2
dim upperx(nshocks) lowerx(nshocks)
do pagetoshow=1,pages
if page==1 {
spgraph(header=header,footer=footer,xpos=both,xlab=xlabel, $
ylab=ylabel,vlab="Responses of",vfields=nshow,hfields=nshocks)
compute shocklower=1,shockupper=nshocks
compute varlower=1,varupper=nshow
else
if page==3 {
spgraph(footer="Responses to "+xlabel(pagetoshow),vfields=nvert,hfields=nhorz)
compute shocklower=pagetoshow,shockupper=pagetoshow
else
if page==4 {
spgraph(footer="Responses of "+ylabel(pagetoshow),vfields=nvert,hfields=nhorz)
compute varlower=pagetoshow,varupper=pagetoshow
else
if page==2 {
compute shocklower=(pagetoshow-1)/nshow+1,shockupper=shocklower
compute varlower=%clock(pagetoshow,nshow),varupper=varlower
do i=varlower,varupper
compute minlower=maxupper=0.0
do j=shocklower,shockupper
set resp(j) 1 steps = 0.0
set lower(j) 1 steps = 0.0
set upper(j) 1 steps = 0.0
if npercent>2 {
set lowerx(j) 1 steps = 0.0
set upperx(j) 1 steps = 0.0
do k=1,steps
* Extract the record (across draws) for the response being graphed
ewise work(t)=%%responses(t)((j-1)*ntargets+yshow(i),k)
* Compute whatever percentiles are needed
compute frac=%fractiles(work,request)
* Choose the central value
if center==1
compute resp(j)(k)=%avg(work)
else
if center==2
compute resp(j)(k)=frac(npercent+1)
else
compute resp(j)(k)=impulses(yshow(i),j)(k)
if %defined(stddev) {
compute sigma=sqrt(%normsqr(work)/draws-resp(j)(k)^2)
compute lower(j)(k)=resp(j)(k)-stddev*sigma
compute upper(j)(k)=resp(j)(k)+stddev*sigma
else {
if npercent>2 {
compute lower(j)(k)=frac(1)
compute lowerx(j)(k)=frac(2)
compute upperx(j)(k)=frac(3)
compute upper(j)(k)=frac(4)
else {
compute upper(j)(k)=frac(2)
end do k
compute maxupper=%max(maxupper,%maxvalue(upper(j)))
compute minlower=%min(minlower,%minvalue(lower(j)))
if page==3
compute gheader=ylabel(i)
else
if page==4
compute gheader=xlabel(j)
else
compute gheader=""
if page==1.and.npercent>2 {
graph(ticks,min=minlower,max=maxupper,number=0,header=gheader) 5 j i
# resp(j) 1 steps
# upper(j) 1 steps 2
# lower(j) 1 steps 2
# upperx(j) 1 steps 3
# lowerx(j) 1 steps 3
else
if page==1 {
graph(ticks,min=minlower,max=maxupper,number=0,header=gheader) 3 j i
# resp(j) 1 steps
else
if page<>1.and.npercent>2 {
# resp(j) 1 steps
else {
# resp(j) 1 steps
if page<>4
end do pagetoshow
grparm(recall=grparms)
end MCGraphIRF
[b][/b]
Posted: Thu Dec 17, 2009 11:08 am
The "i" in this loop is the variable:
If you want a GRID each time series 2 is graphed, add something like:
if i==2
set grid 1 steps = t==KMAX
else
set grid 1 steps = 0.0
then add the option GRID=GRID to all the GRAPH instructions inside the loop.
Posted: Tue Aug 09, 2011 1:01 am
by dennis0125hk
Thanks for your code.
However, I have a question that why simplex algorithm is needed to be performed after genetic algorithm? I am curious that why the genetic algorithm cannot be used alone for obtaining the minimum point since genetic algorithm itself is the optimization tool like simplex algorithm.
Posted: Thu Sep 17, 2015 7:06 pm
dennis0125hk wrote:Thanks for your code.
Genetic is good for a broad scan of the space, but once you've picked a "hill", it takes much longer to reach final convergence. Since this optimization is inside a loop, efficiency matters.
Posted: Sun Jan 17, 2016 8:21 pm
by junlin
Dear all,
I have a question.
How to replicate Figure 1 in paper of Mountford & Uhlig JAE 2009,which is in page 967.
The key point is to get/caculate the series of Business Cycle shock,Monetary Policy shock,Government Revenue shock and Government Spending shock.
The main part of mu2009b1.src is flowed, Can you tell me how to generate the series of Business Cycle shock for example ?
compute nkeep=250
* Pull in common setup
* Range of steps to constrain. Note - these are based at 1, not 0.
compute KMIN =1
compute KMAX =4
* Parameter vectors for the nested optimization problems. They should
* have a size equal to nvar less 1 + the number of constraints imposed
* prior to their estimation. Those prior constraints can be
* orthogonality to previous shocks, or can be zero restrictions.
compute nshocks=4
dec vect[strings] sl(nshocks)
compute sl=||"Business Cycle","Monetary Policy","Revenue","Spending"||
compute [vect] g1 =%fill(nvar-1,1,1.0) ;* Parameters for the first identified shock
compute [vect] g2 =%fill(nvar-2,1,1.0) ;* Parameters for the second identified shock
compute [vect] g3c=%fill(nvar-3,1,1.0) ;* Parameters for the third identified shock (revenue)
compute [vect] g3e=%fill(nvar-3,1,1.0) ;* Parameters for the third identified shock (spending)
compute ones=%const(1.0)
source forcedfactor.src
infobox(action=define,progress,lower=1,upper=nkeep) "Monte Carlo Integration"
* Set control parameters for genetic optimization
nlpar(populate=30,mutate=simple,scalefactor=2.0)
dec real func
do draw=1,nkeep*10
* responses.
compute sigmad =%ranwisharti(svt,wishdof)
compute p =%decomp(sigmad)
compute betadraw=betaols+%ranmvkron(p,sxx)
impulse(noprint,model=varmodel,factor=p,results=impulses,steps=nstep)
gset irfsquared 1 1 = %xt(impulses,t).^2
* First in Order - Business Cycle Vector
* Minimize the penalty function, starting from the last set of minimizers
nonlin g1
find(noprint,pmethod=genetic,piters=50,method=simplex) min func
compute v1=%stereo(g1)
compute func=UhligPenalty(v1,KMIN,KMAX,||+1,+3,+8,+9||)
end find
compute i1=p*v1
* Compute a factor with i1 forced as the first column.
* Transform the orthogonal complement (remaining columns) back into weights on
* the Choleski factor.
compute r2=inv(p)*%xsubmat(f,1,nvar,2,nvar)
* Second in Order - Monetary Shock
nonlin g2
compute v2=r2*%stereo(g2)
compute func=UhligPenalty(v2,KMIN,KMAX,||+4,-5,-6,-7||)
end find
compute i2=p*v2
* Compute a factor with i1~i2 forced as the first two columns.
@forcedfactor(force=column) sigmad i1~i2 f
compute r3=inv(p)*%xsubmat(f,1,nvar,3,nvar)
* Third in Order - Govt Revenue Shock (no delay)
* Draw from the orthogonal complement of i1 and i2 (final nvar-2 columns
* in the factor).
nonlin g3c
compute v3c=r3*%stereo(g3c)
compute func=UhligPenalty(v3c,KMIN,KMAX,||+3||)
end find
compute i3c=p*v3c
* Third in Order - Govt Spending Shock (no delay)
nonlin g3e
compute v3e=r3*%stereo(g3e)
compute func=UhligPenalty(v3e,KMIN,KMAX,||+2||)
end find
compute i3e=p*v3e
* Meets all restrictions
dim %%responses(draw)(nshocks*nvar,nstep)
* Save the desired sets of linear combinations of the Choleski
* responses
compute vweights=v1~v2~v3c~v3e
ewise %%responses(draw)(i,j)=(ik=%vec(%xt(impulses,j)*vweights)),ik(i)
if draw>=nkeep
break
infobox(current=draw)
:newdraw
end do draw
infobox(action=remove)
@MCGraphIRF(model=varmodel,varlabels=vl,shocklabels=sl,$
page=byshock,center=median,columns=2,include=||1,2,10,4,6,8,3,9,5,7||)
Posted: Fri Jan 22, 2016 9:34 am
I'm not sure I know what it is that Figure 1 is actually graphing. The following graphs what I would interpret to be the (bounds on the) structural shocks. However, it doesn't come close to matching Figure 1. I would have anticipated that the structural shocks themselves would be extremely imprecise (as is shown in the graph below) since it's their effect on the observables that really matters---you could flip the signs on the shocks and flip the signs on the loadings onto the observables and get the same result.
- mu2009x3.RPF
- Generation of shocks
- (5.17 KiB) Downloaded 2301 times
Posted: Thu Apr 26, 2018 10:13 am
by junlin
Dear TomDoan,
Thank you for your answer and program.
I am using your program to analyse the relationships of business cycle shock, fiscal expenditure shock and monetary policy shock in China.
Thank you again!
Sincerely,
Junlin Mu
Posted: Thu Jan 10, 2019 12:55 am
by trungbh
Hi Tom Doan,
Thank you for your code.
I have a question about how to display the impulse responses in the form of a table of results, not in the form of the graphs as displayed after running the code. Since I would like to calculate the tax and spending multipliers, it is necessary to know these responses in numbers.
I have replaced the MCGraphIRF
by the MCProcessIRF as follows:
@MCProcessIRF(model=varmodel,irf=irf,lower=lower,upper=upper)
However, after running the whole code, nothing had been displayed. I supposed that something was wrong with my @MCProcessIRF. I have just started studying RATS, so please help me with this issue.
Thank you in advance.
Posted: Thu Jan 10, 2019 8:37 am
@MCProcessIRF does the calculations but doesn't produce any visible output---it's generally used for doing graphs in a different style than @MCGraphIRF.
However, you don't want to produce a table so you can compute the multipliers, because that's doing the calculations in the wrong order---you need to do those calculations as you generate the responses and summarize the results of those. (Arithmetic on the output from @MCProcessIRF doesn't really make sense). Note that that's what is done in the MU example---the linear combinations are taken of the individual responses.
Posted: Sun Jan 05, 2020 3:50 am
by pascal
May I know how to obtain the (values) of impulse responses and the error bands in the form of a table, not in the form of the graphs as displayed after running the code in mu2009x2 ?
Thank you
Pascal
